Henz Tampon inserted, Auto Acquired, next purchase a new handbag Donating Members 9,946 Member For: 17y 1m 25d Gender: Male Location: Vic Posted 06/08/12 09:11 AM Share Posted 06/08/12 09:11 AM Normally 16-17 is were they start to float, and especially with that many kms. My bf2 springs showed signs of float at 17psi, then after 12months started to float at 14-15. Link to comment https://www.fordxr6turbo.com/forum/topic/81302-4-dump-will-it-help-take-the-load-off-valve-springs/page/2/#findComment-1275513 Share on other sites More sharing options...
Robos F6 Donating Members 407 Member For: 16y 2m 14d Gender: Male Location: Vic Posted 06/08/12 10:30 AM Share Posted 06/08/12 10:30 AM I made 304rwkw at 13psi with just a hi flow cat as well. I then fitted 3.5 dump to the hi flow cat with no over mods. Got a re-tune done and it made 314rwkw at 15psi. The peak power only increased 10rwkw which doesnt sound much but it picked up 40rwkw in the middle which makes so much difference. The car now feels so much faster when it comes on boost. I say go for it. Still running stock valve springs. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/81302-4-dump-will-it-help-take-the-load-off-valve-springs/page/2/#findComment-1275563 Share on other sites More sharing options...
XR6menace BANNED Banned 1,462 Member For: 18y 17d Gender: Not Telling Location: banned Posted 06/08/12 12:01 PM Share Posted 06/08/12 12:01 PM Miss ya robbo Link to comment https://www.fordxr6turbo.com/forum/topic/81302-4-dump-will-it-help-take-the-load-off-valve-springs/page/2/#findComment-1275611 Share on other sites More sharing options...
AirStrike Donating Members 387 Member For: 16y 5m 24d Gender: Male Posted 06/08/12 12:09 PM Share Posted 06/08/12 12:09 PM On 06/08/2012 at 4:44 AM, FAST-XR said: thanks for such a useful post!I don't understand, if it needs springs then do them. Why would you worry about the exhaust? I'm making 350+rwkw with a stock dump and exhaust, only upgraded cat. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/81302-4-dump-will-it-help-take-the-load-off-valve-springs/page/2/#findComment-1275617 Share on other sites More sharing options...
stee3 Member 194 Member For: 13y 10m 20d Posted 06/08/12 01:31 PM Share Posted 06/08/12 01:31 PM On 06/08/2012 at 8:02 AM, riptide said: I've been running ~17psi with the same springs and about 180k on the clock and no noticeable float. Just wondering what the PSI limit is with the BFll springs and is there much risk of valve damage etc?We had 420kw out of it on the dyno with the same springs.Never really thought much more about it until reading this.Im with you I have seen over 400rwkw with BF valve springs on at least 6 cars with no problems what so ever.Who is tuning your car? Something is not right mate. You have a BF manual and only 300RWKW with all the mods in your signature? - Personally I think something else is wrong, I think its your fuel pump pressure relief valve. Good luck with it! Link to comment https://www.fordxr6turbo.com/forum/topic/81302-4-dump-will-it-help-take-the-load-off-valve-springs/page/2/#findComment-1275637 Share on other sites More sharing options...
The Outsider Donating Members 1,205 Member For: 14y Gender: Male Location: Burwood, NSW Posted 06/08/12 02:37 PM Share Posted 06/08/12 02:37 PM intune? Link to comment https://www.fordxr6turbo.com/forum/topic/81302-4-dump-will-it-help-take-the-load-off-valve-springs/page/2/#findComment-1275644 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 5m 21d Gender: Male Location: Probably above atmospheric pressure Posted 06/08/12 03:18 PM Share Posted 06/08/12 03:18 PM 170,000km2007 BFII15PSI / 317rwkw (or 322 on new dyno, same tuner) since 100,000kmValves confirmed for going soft and need replacing. I often drive around under boost just to hear the flutter... might have contributed It won't happen overnight, but it will happen. Link to comment https://www.fordxr6turbo.com/forum/topic/81302-4-dump-will-it-help-take-the-load-off-valve-springs/page/2/#findComment-1275649 Share on other sites More sharing options...
FAST-XR EVIL T Member 259 Member For: 16y 5m 7d Gender: Male Location: Liverpool NSW Posted 06/08/12 10:52 PM Author Share Posted 06/08/12 10:52 PM no problems with tuner, saw a 30kw drop off at top end when we went from 14 to 15psi, so we then dropped it to 13psi to be safe...thanks for the replies, looks like we can confirm that valve springs can go soft and be limited to 15psi even in a bf mkII, and upgrading the exhaust will not help much... so springs will need to be done. Link to comment https://www.fordxr6turbo.com/forum/topic/81302-4-dump-will-it-help-take-the-load-off-valve-springs/page/2/#findComment-1275677 Share on other sites More sharing options...
STAINLESS again plz You've changed man.... Donating Members 8,142 Member For: 14y 4m 18d Gender: Male Location: 2 Fuchsia Court, Narre Warren. 3805 Posted 07/08/12 12:14 AM Share Posted 07/08/12 12:14 AM On 06/08/2012 at 4:40 AM, AirStrike said: Or you could just do valve springs.1st reply Link to comment https://www.fordxr6turbo.com/forum/topic/81302-4-dump-will-it-help-take-the-load-off-valve-springs/page/2/#findComment-1275700 Share on other sites More sharing options...
cizzink11 Member 352 Member For: 12y 9m 14d Gender: Male Posted 07/08/12 08:17 AM Share Posted 07/08/12 08:17 AM The only thing I think you will accomplish with a larger dump pipe will be a laggier turbo. The power won't go anywhere it will just come on harder at a higher rpm. Link to comment https://www.fordxr6turbo.com/forum/topic/81302-4-dump-will-it-help-take-the-load-off-valve-springs/page/2/#findComment-1275939 Share on other sites More sharing options...
