ALIAS-XR6T Donating Members 17 Member For: 14y 2m 8d Posted 15/08/12 01:10 AM Share Posted 15/08/12 01:10 AM On 03/08/2012 at 11:00 AM, knoles said: Somebody needs to mount an iPad into the factory facia already!!! Problem solved.True that.I used a product called RE-Q. It takes the high level (speaker) output from any factory head unit, retains the Bass lost and allows you to EQ the signal before running it into your amps. Great product and cheap.I too have a ute and personally have never been a fan of the aftermarket head unit down below (even though we fit them at my work all the time)You can splice into the wiring, but if you go to use the factory ICC, you must have your aftermarket head unit switched off completely.The other option is to buy any head unit (preferbly with rear AUX in for neater install) and then you just use a high to low level converter off the factory ICC and have that run into the AUX in of the head unit. Then basically you have all the features available on your stereo you have bought, plus the 6 Stacker coming from the ICC and playing through AUX in of the stereo.I deal with Car Audio all day long at work. We've done every possibly solution, except iPad's 2 Link to comment Share on other sites More sharing options...
Panda Eyes flame magnet Gold Donating Members 5,674 Member For: 16y 10m 22d Gender: Male Location: adelaide hills- 'race air' central Posted 16/08/12 01:56 AM Share Posted 16/08/12 01:56 AM great idea with the aux input... 1 Link to comment Share on other sites More sharing options...
jrjoz Member 23 Member For: 12y 9m 4d Gender: Male Location: Victoria Posted 17/08/12 08:20 AM Share Posted 17/08/12 08:20 AM With my install I just grabbed the alpine pxe h-660, it has an rca aux in and remote so you can switch sources with the push of a button.Also has separate level control and drops the eq used to correct the HU when you switch sources.Should have it all together in the next couple of weeks so I will let you know how it goes.Also for a ute defiantly look at some dynamat for the rear wall and doors, it's crazy the difference it makes. Link to comment Share on other sites More sharing options...
macca2042 Donating Members 150 Member For: 15y 7m 20d Gender: Male Location: Yarrawonga Posted 18/08/12 12:46 PM Author Share Posted 18/08/12 12:46 PM Hmm so how would the speakers be wired up with the aux using the icc? Through the headunit or icc still? Link to comment Share on other sites More sharing options...
jrjoz Member 23 Member For: 12y 9m 4d Gender: Male Location: Victoria Posted 18/08/12 12:53 PM Share Posted 18/08/12 12:53 PM There are 2 inputs on the processor, the speaker/line converter input will be the ICC and the line level RCA input could be another head unit/iPod whatever.It has a little remote switch to change input sources. Link to comment Share on other sites More sharing options...
