Roadrunna Member 5 Member For: 12y 9m 18d Posted 31/07/12 07:53 AM Share Posted 31/07/12 07:53 AM I've just come back from the drags and I found that I was getting to much lag from my turbo ute, just want to know should I change my standard diff ratio to something different and will that help cause my 60ft time was like 2.9secs. Link to comment https://www.fordxr6turbo.com/forum/topic/81206-diff-gear-ratio/ Share on other sites More sharing options...
bcl Toughest BA Turbo Lifetime Members 3,408 Member For: 22y 4m 23d Gender: Male Location: Sydney Posted 31/07/12 08:24 AM Share Posted 31/07/12 08:24 AM How many drag runs have you done?You need some practice at launching to get the time down.Maybe reduce tyre pressures. Try different launch rpm.What model/trans/tyres have you got. Brian Link to comment https://www.fordxr6turbo.com/forum/topic/81206-diff-gear-ratio/#findComment-1273099 Share on other sites More sharing options...
sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 15y 6m 21d Gender: Male Location: Far north queensland Posted 31/07/12 10:11 AM Share Posted 31/07/12 10:11 AM stock turbo? Link to comment https://www.fordxr6turbo.com/forum/topic/81206-diff-gear-ratio/#findComment-1273192 Share on other sites More sharing options...
Roadrunna Member 5 Member For: 12y 9m 18d Posted 31/07/12 11:29 AM Author Share Posted 31/07/12 11:29 AM Yeah stock I've done the actuator and wastegate that's itSorry I mean flapper not wastegateBa ute mk11 the box is a four speed with 2500 stall and shift kit the tyres are a bridgestone semi slick potenza re55s and the guys from there put 27 psi in themIt was my first run ever Link to comment https://www.fordxr6turbo.com/forum/topic/81206-diff-gear-ratio/#findComment-1273254 Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 5m 25d Gender: Male Location: SE Melbourne Posted 31/07/12 12:37 PM Share Posted 31/07/12 12:37 PM you know you can use the edit button. 27psi is too high Link to comment https://www.fordxr6turbo.com/forum/topic/81206-diff-gear-ratio/#findComment-1273309 Share on other sites More sharing options...
Kosij Donating Members 2,045 Member For: 13y 9m 7d Gender: Male Posted 31/07/12 12:39 PM Share Posted 31/07/12 12:39 PM Did you stall it up at all!I managed 5psi boost off the line with stock 4sp and netted a 1.80 60ft! Link to comment https://www.fordxr6turbo.com/forum/topic/81206-diff-gear-ratio/#findComment-1273310 Share on other sites More sharing options...
Roadrunna Member 5 Member For: 12y 9m 18d Posted 31/07/12 10:03 PM Author Share Posted 31/07/12 10:03 PM It sounds like I didn't do things right for the first time, I tried stalling but I was more focused on the tree and now it sounds like the tyre pressure was to high, I'll try again next meet and do it properly this time Link to comment https://www.fordxr6turbo.com/forum/topic/81206-diff-gear-ratio/#findComment-1273342 Share on other sites More sharing options...
Kosij Donating Members 2,045 Member For: 13y 9m 7d Gender: Male Posted 31/07/12 10:10 PM Share Posted 31/07/12 10:10 PM Don't focus on your reaction time. Focus on stalling it up and then leaving the line on boost this will better your 60ft time. Link to comment https://www.fordxr6turbo.com/forum/topic/81206-diff-gear-ratio/#findComment-1273345 Share on other sites More sharing options...
sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 15y 6m 21d Gender: Male Location: Far north queensland Posted 31/07/12 10:16 PM Share Posted 31/07/12 10:16 PM yep don't worry about being the first across the line, take your time and practise Link to comment https://www.fordxr6turbo.com/forum/topic/81206-diff-gear-ratio/#findComment-1273346 Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 5m 25d Gender: Male Location: SE Melbourne Posted 31/07/12 11:00 PM Share Posted 31/07/12 11:00 PM Some people think the time starts as soon as the light goes green. It's not the case. The time doesn't start until the car rolls over the "start line". Link to comment https://www.fordxr6turbo.com/forum/topic/81206-diff-gear-ratio/#findComment-1273348 Share on other sites More sharing options...
