  • Hench, but no longer shredded or tanned.
  • Member For: 18y 1m 4d
Im not 100% certain but I think people have been having issues with the aftermarket rails fitting. Unless the issue is sorted now
  • Moar Powar Babeh
  • Member For: 19y 7m 9d
I had issues with an aftermarket rail from Injectors on line. Was fine with dekas but once I swapped over to ID's the misalignment between the injector bore in the manifold and rail cause many issues with fuel leaks between the injector and adaptor hat.
You may be okay if only using long injectors.
  • Member For: 13y 4m 4d
  On 14/11/2013 at 2:23 AM, raz1911 said:
Do you have to cut much to make the 600x300 cooler to fit? Also is it hanging lower than the front bar?
I had to cut the lip off the Reo that supports the front bar and had to modifie the aircon condensor. at first I made brackets and it hung lower then front bar (VL leb spec) then I remade them and now it sits up in the bar
  • 2 weeks later...
