  • Member For: 16y 11m 5d
I have no boost leaks and no vacuum leaks.
The only faults I'm getting is p1507 and p0171.
Fuel pressure was checked by mechanic he believes it had great fuel pressure.
What's happening is the car will boost fine any gear then it will just go to no boost randomly.
I will accelerate and it will make no attempt on boosting then if I take my foot off the gas pedal and place it back on it will hit boost again.
Then the process again will start all over again.
The car is tuned to a max boost of 18psi but seems to hit 21 psi on the street sometimes.
Does anyone think it might be going into limp mode because of it.
The car has all the goodies , I.e wastegate mod and act., 1000hp cooler, plenum, exhaust, and so on. Nothing out of the ordinary anyway.
https://www.fordxr6turbo.com/forum/topic/81199-help-boost-problem/
  • 4 weeks later...
  • Member For: 13y 10m 22d
sounds like boost cut. Mines doing the same thing sometimes, but I'm not getting any error codes.
I never get any error codes, I dont even think mine works...
  • 1 month later...
