Bellato Donating Members 2,713 Member For: 14y 3m 20d Posted 02/08/12 04:06 AM Author Share Posted 02/08/12 04:06 AM 1.8 isn't too bad, I was under the assumption that at about 0.5 you;d still get pretty even tyre wear, bringing it in a bit over a degree shouldn't be too hard.Also need to note that it is much harder for Stiflr to get around at that height given the lower height of the FPV bodykit so for practicality purposes you probably couldn't go much lower Link to comment Share on other sites More sharing options...
wa g6et Member 657 Member For: 13y 8m 5d Gender: Male Location: Perth NOR Posted 02/08/12 04:26 AM Share Posted 02/08/12 04:26 AM hahaha yer ill wash them.yer get a camber kit for the front a must. I got shims in mine atm but it still has neg camber. the suspension place said for a daily street car you want 0 deg of camber.My suspension shop set me up at 0.8deg neg camber on the front. Compromise between wear and handling for the street. Link to comment Share on other sites More sharing options...
bossmang FREAKY Donating Members 12,434 Member For: 15y 1m 14d Gender: Male Location: Melbourne Posted 02/08/12 08:58 AM Share Posted 02/08/12 08:58 AM .8 deg camber you recon ey?do you or anyone know what stock camber is set at? Link to comment Share on other sites More sharing options...
Bellato Donating Members 2,713 Member For: 14y 3m 20d Posted 02/08/12 09:45 AM Author Share Posted 02/08/12 09:45 AM Can't find my wheel alignment printout for the FG but found an old one off my BA XR6 (done at Ford). On the front they adjusted it to 0.52 degrees left and 0.63 degrees right.So I guess half a degree would be what the stock is because you'd assume they should adjust it to what Ford makes the cars with.But like I said this is a BA so FG may or may not be different Link to comment Share on other sites More sharing options...
Bomber Carnage on the Garage Floor Donating Members 3,994 Member For: 14y 8m 28d Gender: Male Location: Gold Coast Posted 02/08/12 10:14 AM Share Posted 02/08/12 10:14 AM Stock is over 1.0 deg neg. Link to comment Share on other sites More sharing options...
Bellato Donating Members 2,713 Member For: 14y 3m 20d Posted 02/08/12 10:25 AM Author Share Posted 02/08/12 10:25 AM that's a lot of Neg camber from standard, that's definately going to scrub out the insides!Why would they set them at neg 1.0 from factory but then get their mechanics to do less than that when car's get wheel aligned, classic ford lol Link to comment Share on other sites More sharing options...
STIFLR Donating Members 572 Member For: 16y 1m 30d Gender: Male Location: Victoria Posted 02/08/12 11:31 AM Share Posted 02/08/12 11:31 AM Bellato, do you how much adjustment there is available in the super pro camber kits? With needing 1+ deg of adjustment, will these be ok or should I go the k-macs? Link to comment Share on other sites More sharing options...
Bellato Donating Members 2,713 Member For: 14y 3m 20d Posted 02/08/12 11:41 AM Author Share Posted 02/08/12 11:41 AM To be honest I've never used them but I think the only difference between the Superpro and the K-mac kits is that the Superpro is shims and the K-mac is ratchet style. Id say they both have a fairly similar range of adjustment. I do remember though when my Ba was lowered my mate who worked at Bob Jane and did my wheel alignment told me that if need be I should chuck in a shim or 2 (prob only 1mm shims) and that would bring it back out. Given you don't need much adjustment I'd say both kits will do the job, its just a matter of which you want to use. If you'll install and do yourself probs K-mac cause easier to use, but if your mechanic is going to do it, go superpro and let him adjust the shims as need be lolMaybe WA could better answer this so hopefully he'll chime in.Also you didn't have any negative rear camber did you Stiflr? Link to comment Share on other sites More sharing options...
bossmang FREAKY Donating Members 12,434 Member For: 15y 1m 14d Gender: Male Location: Melbourne Posted 02/08/12 12:01 PM Share Posted 02/08/12 12:01 PM hey PAT can you give some insight as to which camber kit up front is most reliable option? superpro or kmac? Link to comment Share on other sites More sharing options...
STIFLR Donating Members 572 Member For: 16y 1m 30d Gender: Male Location: Victoria Posted 02/08/12 12:48 PM Share Posted 02/08/12 12:48 PM To easy Bellato, Cheers. Just done a quick calc, there's approx .8-1deg on the rears. Can barely notice it. You there PAT??? haha Link to comment Share on other sites More sharing options...
