Ba/bf Engine Strengthening
allmtr
  • Member For: 15y 10m 29d
Looking at strengthening my BF motor to take mid 400's
Thinking of Spool rods, atomic balancer and atomic oil pump
Anything else to look into?
I really only want similar strength to an F6 motor as they seem to take that kind of power and I don't need something that can take 698kw or anything
The other option is to just throw a new FG motor in it...
Thoughts?
  • Member For: 18y 8m 9d
Balancing
Rings to suit
Engine rebore and recommend line boring
Hot tank clean
Block crack tested
Block deck height checked/machined
Crank Grind or linish
Crack testing crank
Timing chain
Timing chain guides
Timing Chain Tensioner
Rear Main Oil seal
Timing Case oil seal
Sump gasket
Timing case gaskets
Head Bolts
Head overhaul
Rocker cover gasket
Rocker cover seals for spark plug wells
Cam phaser seals
Inlet manifold gasket
Exhaust manifold gasket
Welsh plugs
If you going to do it, do it properly
  • New Member
  • Member For: 12y 6m 7d
Ba and fg rods and pistons are exactly the same the only difference from factory is the exhaust manifold and the inlet manifold other then that all the same
Just call brad at atomic he will tell u he's been building ford motors since the dinosaurs
I just don't see the need in $8k for a bottom end when a $3k one will do what I need
CMEFRY: BF II onwards rods are stronger than BA/BF
  • Member For: 22y 1m 12d
If you already have the answer, don't ask the question :idunno:
  • Member For: 16y 2m 14d
Are you serious? been online for 32mins and already a pro? or do you work for atomic?
Maybe a banned user? who knows. Anyway you sir are wrong.
Edited by Paulie2256
  • Member For: 14y 6m 10d
Mate by the time you through all the hassle of getting all the stuff done as ratter said ud be better off in my opinion if your only chasing 400s go with a fg f6 bottom end. Plus depending on your location u have to find a good engine builder. Bionicxr6t helped me source mine for under 3k to my door. But you will still need to go your usual atomic oil pump, hd timing chain and sprocket, New guides and tensioner. And get your head checked by a decent mob and valve springs if you don't have them already. I also went a vrs kit from atomic so u can get the new valve stem seals put in the.head and ull have all your New seals u need. But I did hear that ford aren't making them with the Bf dipstick. Which will make for a pain in the ass due to the sumps being back to front in the fg. But I'd did also hear that some shops have a jig setup to drill the second hole in the fg block to make it suit Bf.
Quick side question ratter I didn't think that ford used a sump gasket on there motors only gasket goo... If so do u use a gasket and where abouts you get them from...
Sent from my HTC Velocity 4G using Tapatalk 2
