jas98 Member 1,046 Member For: 12y 7m 10d Gender: Male Location: Maryborough Qld Posted 29/07/12 04:51 AM Share Posted 29/07/12 04:51 AM hi if I make a custom pod air box for my BA XR6T stock standard would I need a tune? im thinking of making a pod enclosre as the standard factory filter which is brand new does not f*cking let air in as you cannot even blow through it.....wtf is with that lolcheers Link to comment Share on other sites More sharing options...
PookeyMaster Donating Members 1,531 Member For: 14y 2m 13d Gender: Male Location: Parramatta, NSW Posted 29/07/12 05:08 AM Share Posted 29/07/12 05:08 AM I think the general rule is you only need a tune for mods to the engine or post engine. Anything pre engine like the air box is fine. Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 9m 5d Gender: Male Location: @ my laptop Posted 29/07/12 05:13 AM Share Posted 29/07/12 05:13 AM there is no rule, pretty much anything that affects total air flow will have an affect on boost, if the tune is in closed loop boost control, then the ecu will keep the boost as it was but the error will be higher, if in open loop and air flow is increased then boost will rise and really needs to be corrected to suit rather than risk damage, but increasing air flow to the turbo may not increase total airlfow if there are other restrictions, I.e cooler, exhaust etc 1 Link to comment Share on other sites More sharing options...
jas98 Member 1,046 Member For: 12y 7m 10d Gender: Male Location: Maryborough Qld Posted 29/07/12 05:56 AM Author Share Posted 29/07/12 05:56 AM hmm well stock cooler with a x forch cat back exhaust, juts really wannna get rid of the sh*t factory filter, I can not even blow into it Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 9m 5d Gender: Male Location: @ my laptop Posted 29/07/12 06:07 AM Share Posted 29/07/12 06:07 AM have tested a clean FG stock filter against a K&N filter on a car making approx 315 rwkw, no benefit with the K&N over the stock one, have not done the same comparison with a BA/F filter though, but can't see there being too much difference 1 Link to comment Share on other sites More sharing options...
Impellor Member 835 Member For: 14y 7m 12d Gender: Not Telling Posted 29/07/12 06:08 AM Share Posted 29/07/12 06:08 AM Go for your life mate. Adding a pod to the factory airbox will not cause you any grief with only a catback exhaust. Cheers Link to comment Share on other sites More sharing options...
jas98 Member 1,046 Member For: 12y 7m 10d Gender: Male Location: Maryborough Qld Posted 30/07/12 01:02 AM Author Share Posted 30/07/12 01:02 AM yeah, well I cannot understand why the filter is clogged and its new? I mean like you cannot blow through the thing, same with other one that was in it, also its ryco brand. White papery material. I was always under the impression that if air cannot get or is restricted then car wilnot go as good and chew more fuel Link to comment Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 15y 1m 14d Gender: Male Location: Christchurch, New Zealand Posted 30/07/12 03:13 AM Share Posted 30/07/12 03:13 AM when you say blow threw it are you meaning an air gun or just you blowing through it. It probably isnt going to be noticeably just blowing threw it with your mouth, I wouldnt expect it to be blocked. Is there anyother reason you want to change the intake. Link to comment Share on other sites More sharing options...
jas98 Member 1,046 Member For: 12y 7m 10d Gender: Male Location: Maryborough Qld Posted 30/07/12 05:08 AM Author Share Posted 30/07/12 05:08 AM hmm well even if I put it up close and blow througfh it I cannot really feel any air at all, which like I said it feels like its blocked, and would like a better flowing filter and I have a pod that is easyly able to blow through it Link to comment Share on other sites More sharing options...
macca2042 Donating Members 150 Member For: 15y 6m 14d Gender: Male Location: Yarrawonga Posted 08/08/12 08:52 AM Share Posted 08/08/12 08:52 AM I have the growler airbox setup inmy ute, it has greatly increased the air flow into the motor but it wont over boost due to the cat in the exhaust and the dump pipe still being standard. if the turbo cannot spool up any quicker or harder than the factory tune has allowed then ou wont have any problems. so if you wanna go with the pod setup then maybe afterwards just get a checkup on the dyno purely to make sure its not pulling lean under boost.. Link to comment Share on other sites More sharing options...
