  • Bronze Donating Members
  • Member For: 13y 8m 26d
As in take it to someone who knows what their doing mate! Intune, by all reports, are useless, you have waaaaaay better options in that area
  • Member For: 13y 2m 18d
thanks I will ring a few up tomorrow any Suggestions Edited by dazza009
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 10m 22d
ping tune motorsports
run run now
go see tunehouse,cvperformance,bta,autotech
Edited by JETSNOT
  • Member For: 19y 9m
I agree with the above.
1. check they are genuine.
2. check the injector slopes and offset used, they should be similar to the values suggested in this forum. Also, a knowledgeable guy did some testing here: http://www.calibratedsuccess.com/Assets/Documentation/WhosGettingDrilled.pdf
... make a decision from there.
Good luck!
  • Member For: 13y 8m 12d
Go see sprio at Autotech at Granville! Won't let ya down!
Don't give intune a single cent! They should
Be open for business! Do some research there are alot I horror story's! Run while you can!
  • Member For: 18y 10m 26d
  On 26/07/2012 at 9:16 AM, dazza009 said:
hi all I am new here and need help just want to know if anyone has had this problem I have a flash tuner 12psi actuator ported waist gate cat back exhaust and front mount intercooler went in today to have seaman's 650cc 60lb injectors put in and a tune.he rings me and says he cant tune. and he is a ford tuner he said it was running way to much fuel and could not get it to run right changed fuel reg no difference put old ones back in and it runs fine at 256kw on 10psi auto trans any help would be appreciated
how do you run a 10 psi tune with a 12 lb actuator?
Who supplied the injectors?
Any chance you may have 80 lb injectors by mistake?
This is one reason we flow test supplied injectors
  • Like 2
they supplied and took them back out
