  • Member For: 15y 3m 26d
So they supplied something they cant even tune, owesome.
And yea 10psi tune with 12psi act, something sounds dodgey. Did they also do the actuator work, or not as the case may be.
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 11m 13d
  • Member For: 17y 5m 20d
  • Member For: 13y 3m 10d
  On 26/07/2012 at 9:16 AM, dazza009 said:
hi all I am new here and need help just want to know if anyone has had this problem I have a flash tuner 12psi actuator ported waist gate cat back exhaust and front mount intercooler went in today to have deka 650cc 60lb injectors put in and a tune.he rings me and says he cant tune. and he is a ford tuner he said it was running way to much fuel and could not get it to run right changed fuel reg no difference put old ones back in and it runs fine at 256kw on 10psi auto trans any help would be appreciated
