  • Member For: 14y 9m 11d
Hey guys,
Ive done afew searches but cant really find anything similar to my question.
My question is, I have a completely stock (centre muffler removed) 5 speed ba xr6t, and I want to purchase an ebay monza cooler that fits directly on to the stock setup. Will I need a tune after doing this, or will this be okay since my car is completely stock?
Thanks in advance,
P
  • Bronze Donating Members
  • Member For: 13y 9m 23d
Well put it this way , I did it I dragged it and flogged it everywhere else, it was fine, factory pcm has enough room to compensate easily BUT its still recommended to check on the dyno
  • Skid Machine
  • Member For: 13y 11m 26d
The Monza will be fine to slap straight on as it doesn't work much more efficiently than the stocker. It'll be fine for standard boost.
  • Member For: 14y 4m 1d
It's a difference in pressure drop when swapping coolers that's the danger. Factory ecu can only do do much to control boost if new cooler works more efficiently.
It should be ok. But as mentioned, get it on a dyno for a check.
