bionicxr6t05 Bronze Donating Members 2,216 Member For: 13y 5m 15d Gender: Male Posted 25/07/12 07:58 AM Share Posted 25/07/12 07:58 AM (edited) If the radiator splits generally it milkshakes the auto in the early ones and then the box needs to be rebuilt but sometimes they only pump auto fluid into the coolant and not vice versa... Strange I would never give my car to someone without knowing full well what they had done...Edit: thought u said it was surging not missing?? Edited 25/07/12 08:01 AM by bionicxr6t05 Link to comment Share on other sites More sharing options...
rotorboyazza Member 21 Member For: 12y 5m 26d Posted 25/07/12 07:30 PM Author Share Posted 25/07/12 07:30 PM The trans has been rebuilt, about 4 weeks ago,at a semi retired mechanics house,he told me all the gears were worn and some shaft was buggered (have the box of old parts he replaced),water from old split radiator/cooler had gone in and buggered the solenoids so he replaced them too and the radiator/cooler was replaced in May ($1600 NZ$) from Ford over here, yes the motor surges in drive, starts at about 40kms rev counter goes from about 1000/1500rpm up to around 2500/3000rpm and drops back down and up agin etc etc,does it when it's cold/warm and also at norm temp,some days it does it and other days it's fine....Now our work ute will be coming home with me on Friday,so I can swap over the TPS and try that, it's a 2006 XR6 but it has a different front bumper than mine, would that make it a BF? Also if the TPS isn't the prblem would it be an ECU issue? Link to comment Share on other sites More sharing options...
rotorboyazza Member 21 Member For: 12y 5m 26d Posted 06/08/12 02:01 AM Author Share Posted 06/08/12 02:01 AM Hey Guys, I have tested the car the last week with a TPS from a BF XR6 (non turbo) and it still does the surge, but not as often and not at the 2500RPM side only around 1000-1500RPM, any ideas? Link to comment Share on other sites More sharing options...
FTTG New Member 1 Member For: 14y 3m 4d Gender: Male Posted 06/08/12 10:07 AM Share Posted 06/08/12 10:07 AM Maybe blocked cat ? Link to comment Share on other sites More sharing options...
Mr_4.0 Member 1,096 Member For: 13y 11m 23d Posted 06/08/12 10:39 AM Share Posted 06/08/12 10:39 AM I'll ask a silly question....Has it been tuned? Link to comment Share on other sites More sharing options...
rotorboyazza Member 21 Member For: 12y 5m 26d Posted 06/08/12 08:11 PM Author Share Posted 06/08/12 08:11 PM Hey guys, no it hasn't been tuned it is stock standard apart from the bolt on exhaust....now can I cut the cat out and run a straight pipe? Last night it stalled/cut out on me 3 times, in traffic, like it was flooded or had a block....gurrrrr Link to comment Share on other sites More sharing options...
_Velocity_ Bronze Donating Members 2,768 Member For: 13y 8m 17d Gender: Male Location: Victoria Posted 07/08/12 12:33 AM Share Posted 07/08/12 12:33 AM Don't gut the cut unless you want to tune it. Go get another stock cat and install it if you really think it is this. Second hand they are around 200 bucks from the wreckers. Link to comment Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 14y 11m 24d Gender: Male Location: Christchurch, New Zealand Posted 07/08/12 02:19 AM Share Posted 07/08/12 02:19 AM You say bolt on exhaust, is this bolted on from the turbo back or from the cat back? Link to comment Share on other sites More sharing options...
rotorboyazza Member 21 Member For: 12y 5m 26d Posted 07/08/12 04:38 AM Author Share Posted 07/08/12 04:38 AM It has a cat back bolt on exhaust, so tomorrow and $150 it will have the cat removed and a twin straight pipe welded on, hopefully that fixes the problem..... Link to comment Share on other sites More sharing options...
Kosij Donating Members 2,045 Member For: 13y 5m 1d Gender: Male Posted 07/08/12 04:55 AM Share Posted 07/08/12 04:55 AM (edited) You CAN'T run without a cat without a retune!! Boost spiking will be your next best friend... Then a new motor! Edited 07/08/12 04:56 AM by Kosij Link to comment Share on other sites More sharing options...
