JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 8m 9d Gender: Male Location: Adelaide Posted 26/02/19 10:18 AM Share Posted 26/02/19 10:18 AM Why do you want to see a set point you configured ? Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,119 Member For: 10y 11d Gender: Male Location: South Australia Posted 26/02/19 10:19 AM Share Posted 26/02/19 10:19 AM I need to replace the gauge for my innovate wideband. One of the leds has died. It's still usable but they are cheap enough to replace...one day lol. Link to comment Share on other sites More sharing options...
bossmang FREAKY Donating Members 12,434 Member For: 15y 1m 15d Gender: Male Location: Melbourne Posted 26/02/19 10:19 AM Share Posted 26/02/19 10:19 AM On 13/02/2019 at 9:02 PM, Rab said: Or grab a Dare Iced Coffee Double Espresso and stop being hangry soft....tripple if your a real man On 13/02/2019 at 9:03 PM, Rab said: Coz he got it cheap or it looked good? Am tipping he doesn't need 4 groupheads dunno hes just really into coffee I guess and wanted the best of the best lol Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,036 Member For: 9y 9m 18d Gender: Male Location: Canberra ACT Posted 26/02/19 10:28 AM Share Posted 26/02/19 10:28 AM Car is going pretty flamin rich sometimes, so I want to know if either a) the tune is genuinely commanding that or b) something is amiss either with the wideband sensor or the fuel system.Car is tuned but I haven't touched it myself yet. Stock injectors and LTFT hovers around 5% so suspicious of something in the fuel system.Want to understand before I chuck in injectors and pump, but then again the injectors might fix it. Need to chuck the fuel pressure gauge on it too. Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,036 Member For: 9y 9m 18d Gender: Male Location: Canberra ACT Posted 05/03/19 09:55 PM Share Posted 05/03/19 09:55 PM You'll have to let us know how it goes [mention=83223]El Andrew[/mention]Arrived on Friday. So far, so good. Pretty easy to work with once you read the programming instructions.I ordered the MX version with Ford CAN option for some preloaded gauges. This includes trans temp and you just need to edit one parameter to change it to Celsius.There's not heaps of information out there about Ultragauge, but there is about Scangauge, including heaps of configurations for OBD parameters not included on the device by default. This is useful as the Ultragauge includes information for converting known Scangauge configurations to Ultragauge. I also found something to convert Torque to Scangauge, so with a double hop anything you can see in Torque is theoretically achievable without getting too sophisticated.I got trans gear sort of working in the driveway this morning, but for some reason will only show gears 1 to 4. Instructions have some debugging info which will be my next step. Learning more about hex and bytes than I intended but not too bad once you get into it.Also the standard OBD parameter for coolant temp fluctuates between -40 and the actual coolant temp on our cars. Scangauge have an alternative configuration to fix this on their website, but converting that to Ultragauge isn't working for me yet. If anyone else grabs these and wants to nick my settings, let me know. Once I sort them out a bit more I'll post them as there is almost nothing on the web that's directly usable. 1 1 Link to comment Share on other sites More sharing options...
bossmang FREAKY Donating Members 12,434 Member For: 15y 1m 15d Gender: Male Location: Melbourne Posted 06/03/19 09:10 AM Share Posted 06/03/19 09:10 AM aint no body got time to read all those gauges Link to comment Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 5m 5d Gender: Male Location: Townsville Posted 11/03/19 06:39 AM Share Posted 11/03/19 06:39 AM So I impulse bought the Innovate MTX-L PLUS wideband AFR setup the other day from Ebay. Is this gauge all I need to view and log with my laptop and PCMTEC (or xcal3) when they release a datalogging update? On 06/03/2019 at 7:55 AM, El Andrew said: Arrived on Friday. So far, so good. Pretty easy to work with once you read the programming instructions. I ordered the MX version with Ford CAN option for some preloaded gauges. This includes trans temp and you just need to edit one parameter to change it to Celsius. There's not heaps of information out there about Ultragauge, but there is about Scangauge, including heaps of configurations for OBD parameters not included on the device by default. This is useful as the Ultragauge includes information for converting known Scangauge configurations to Ultragauge. I also found something to convert Torque to Scangauge, so with a double hop anything you can see in Torque is theoretically achievable without getting too sophisticated. I got trans gear sort of working in the driveway this morning, but for some reason will only show gears 1 to 4. Instructions have some debugging info which will be my next step. Learning more about hex and bytes than I intended but not too bad once you get into it. Also the standard OBD parameter for coolant temp fluctuates between -40 and the actual coolant temp on our cars. Scangauge have an alternative configuration to fix this on their website, but converting that to Ultragauge isn't working for me yet. If anyone else grabs these and wants to nick my settings, let me know. Once I sort them out a bit more I'll post them as there is almost nothing on the web that's directly usable. I own the Aeroforce obd2 gauges that work well. They were for the BA but now are in the Territory. Only issue is they cycle on/off continuously every few minutes when the car is locked so for now I use an adapter with a switch but guess it's a slight wiring difference from 2003 BA turbo to 2008 TT. No issues with 1-6 gear selection in the ZF though and reads everything else correctly that it can read (coolant,head temp,trans temp,boost,MAP,IAT,STFT,LTFT......). Can't see the screen properly with polarised sunnies on which is a drag in Nth Qld! Link to comment Share on other sites More sharing options...
Panda Eyes flame magnet Gold Donating Members 5,674 Member For: 16y 8m 24d Gender: Male Location: adelaide hills- 'race air' central Posted 11/03/19 07:45 AM Share Posted 11/03/19 07:45 AM not stuff I 'just' bought- got my new trailer a few months ago. out grew my old one- both in size and weight. this will carry 2 tonne, and has electric brakes. also wont rust or have paint flake off like my last one so future proof. will prob outlast my career lol. had to drive to Dandenong to get it though cause would have to sell a kidney to buy one in SA. sigh. 3 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,119 Member For: 10y 11d Gender: Male Location: South Australia Posted 11/03/19 07:57 AM Share Posted 11/03/19 07:57 AM 8 minutes ago, Panda Eyes said: has electric brakes This is one upgrade I want to do to my trailer. It's 8x5 tandem with a 10x5 enclosure, and while the cable/drum brakes work, I would feel much better about carrying heavy loads if the brakes were modernised. Link to comment Share on other sites More sharing options...
Rab WOT? Moderating Team 10,981 Member For: 11y 11m 15d Gender: Male Location: Frankston, 3199 Posted 17/03/19 11:38 AM Share Posted 17/03/19 11:38 AM Dropped into JB-HiFi to get a cheap phone for the daughter after I got home from the Tassie trip. @EvilDaifu had an unbelievable drone on the cruise. Yeah, I should have sent her to the shop alone. 2 1 Link to comment Share on other sites More sharing options...
