.Stripes. All stock bar the k&n panel filter Silver Donating Members 8,061 Member For: 13y 3m 23d Gender: Male Location: Perth Posted 01/06/18 10:58 PM Share Posted 01/06/18 10:58 PM Yeah mine has a drain hose that runs to the sink too. So nice knowing that I now don't need to plan so far ahead with my washing, I can just throw it in whenever (irrespective of the weather) and know I have means of drying it in a reasonable time. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/81090-cool-stuff-you-just-bought/page/471/#findComment-1658466 Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 13y 7m 6d Gender: Male Location: WA, Perth Posted 06/06/18 01:02 AM Share Posted 06/06/18 01:02 AM now I know why you need a solar station on your roof.... Link to comment https://www.fordxr6turbo.com/forum/topic/81090-cool-stuff-you-just-bought/page/471/#findComment-1658619 Share on other sites More sharing options...
Rab WOT? Moderating Team 10,981 Member For: 12y 4m 11d Gender: Male Location: Frankston, 3199 Posted 17/06/18 06:09 AM Share Posted 17/06/18 06:09 AM New fermenter. Pale ale just went in. Got myself a proper keg setup (fridge, 2 taps, gas, kegs etc) I'm currently putting together. Hopefully it'll all be setup and ready in a week or so when the beer's ready. Was so over the bottling of the brews that I'd not done any for a while - this should be a hell of a lot easier and constant. No more secondary ferment, adding sugars to carbonate etc and no more cleaning bottles. Half hour at each end of the brew instead instead of hours and only a week or so before the beer is on tap instead of a month or longer. The new fermenter will let me brew and dispense under pressure - should let everything be a closed loop from when the yeast is added til when the beer is poured. Beer should be a lot cleaner, clearer and have far less chance of infection or "off" flavours - no more banana beer Have also got a nitrogen bottle and tap coming - proper pub "Guinness" and "Kilkenny" etc will be an awesome option. Have still got the "Beer droid" fermenters - will use them for the "small batch" beers - they do 10l so will go straight from them to a 10l keg to chuck on the taps. 3 Link to comment https://www.fordxr6turbo.com/forum/topic/81090-cool-stuff-you-just-bought/page/471/#findComment-1659082 Share on other sites More sharing options...
Renton Member 151 Member For: 7y 3m Gender: Male Location: Perth Posted 17/06/18 12:45 PM Share Posted 17/06/18 12:45 PM Always wanted to go a kegerator or fridge set up when I was brewing. Definitely agree the bottling and waiting process gets old pretty quick. Is that a glass or plastic fermenter? Never seen one like that. Does the do hickey down the bottom just catch the sediment? Link to comment https://www.fordxr6turbo.com/forum/topic/81090-cool-stuff-you-just-bought/page/471/#findComment-1659132 Share on other sites More sharing options...
Rab WOT? Moderating Team 10,981 Member For: 12y 4m 11d Gender: Male Location: Frankston, 3199 Posted 17/06/18 01:43 PM Share Posted 17/06/18 01:43 PM 58 minutes ago, Renton said: Is that a glass or plastic fermenter? Fermentasaurus?? from Keg-King https://www.keg-king.com.au/fermentasaurus-starter-kit.html.html It's plastic, but fully pressure capable - has proper gas and liquid disconnect cap on top - something you don't get with the usual bucket fermenters. The plastic it's made of is meant to be very "non-porous" - shouldn't need much more than a rinse and a sanitise to be ready for the next brew. Will go to 30+psi safely - I'll keep it around 12 max. Beer will already be mostly carbed once it's kegged rather than having to worry about let it wait a week to take up the CO2. Fermenting under pressure is meant to let you go quicker, hotter and have keep the esters a non-issue. Larger at Aussie room temp rather than having to keep it as a mid winter brew should be an option. $129 plus another $40 or so for the pressure cap option. The bottle down the bottom lets you remove the trub/sediment mid brew (is a valve stopper) and also lets you add dry hops or finishers without exposing any of the brew to oxygen - remove bottle, empty crap, sanitise, purge with co2, add hops etc, reconnect, open valve. Lets you also take the yeast cleanly to harvest for a next brew. Going the pressure cap option it lets me keg the brew from the top rather than from the bottom - float and tube draw it from the top rather than draining it. Straight from fermentor to keg - no need to worry about secondary etc - all the crap stays at the bottom, only the good stuff is taken from the top. Got 4 19l Kegs 2nd hand and a 10l one. Also got a 4l "growler" (not all through "keg-king") That should give me a few beer options on tap at a time, the 10l for the "small batch"/experiments and the growler (about 12 stubbies) to take out the back or to a mates place - all of those filled under pressure, fully carbed and zero chance of degradation. Also got the nitro setup to run stouts etc - won't be an often thing, but the option will be welcome. (basically a different spout for the tap and a bottle/regulator for the gas) Nothing beats pouring a Guinness (I actually prefer nitro Kilkenny - which I'll be doing) properly. 58 minutes ago, Renton said: Definitely agree the bottling and waiting process gets old pretty quick. That's what made me give up - the "Beer droid" system only did 10l at a time and was a PITA to clean up and bottle. I'll use the droids moving forward to make my own "small batches" and also for the nitro stouts, porters and reds etc, but they'll be straight to the keg - zero secondary to carb up etc. Will also use the 10l's for random stuff like ciders, ginger beer and alco lemonade etc If you had an interest in brewing before - definitely look into it again with kegs. Cheap ($50??) local gumtree freezer, couple of taps ($20ea??), disconnects ($40??) fittings and lines ($$fark all), kegs ($40ea 2nd hand??) etc CO2 bottle and regulator you're all good As an early "brew my own" I reckon it'll cost me $20 a slab (to put it into normal speak) for my beer moving forward max - will get cheaper as I get better They'll also be quality/flavour of the slabs that are normally $60+ $20 for me to invite the mates round - pour cold beer off the tap - change kegs for a different brew etc. Damn - that'll be cheap (especially when I put up the "Tip-Jar $2 Pint" ) Link to comment https://www.fordxr6turbo.com/forum/topic/81090-cool-stuff-you-just-bought/page/471/#findComment-1659133 Share on other sites More sharing options...
Panda Eyes flame magnet Gold Donating Members 5,674 Member For: 17y 1m 20d Gender: Male Location: adelaide hills- 'race air' central Posted 18/06/18 10:57 AM Share Posted 18/06/18 10:57 AM starting to venture away from consoles and explore PC gaming. so bought on eof these: https://www.acer.com/ac/en/US/content/predator-helios300-series https://www.logitechg.com/en-my/product/g403-prodigy-wireless-gaming-mouse https://www.logitechg.com/en-au/product/g533-wireless-gaming-headset crazy that headphones can create full surround. so cool to listen to 1 Link to comment https://www.fordxr6turbo.com/forum/topic/81090-cool-stuff-you-just-bought/page/471/#findComment-1659162 Share on other sites More sharing options...
Rab WOT? Moderating Team 10,981 Member For: 12y 4m 11d Gender: Male Location: Frankston, 3199 Posted 18/06/18 11:24 AM Share Posted 18/06/18 11:24 AM Very nice Only time consoles win is for any exclusives that aren't on PC - otherwise PC 100% of the time. 27 minutes ago, Panda Eyes said: crazy that headphones can create full surround. so cool to listen to Hehe - definitely something that needs to be heard to be appreciated Movies and games in full surround sound through the PC using headphones is awesome. Better sound than most peoples home cinema setups and can use it as loud as you want without waking the household. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/81090-cool-stuff-you-just-bought/page/471/#findComment-1659163 Share on other sites More sharing options...
Renton Member 151 Member For: 7y 3m Gender: Male Location: Perth Posted 18/06/18 12:34 PM Share Posted 18/06/18 12:34 PM 22 hours ago, Rab said: Fermentasaurus?? from Keg-King https://www.keg-king.com.au/fermentasaurus-starter-kit.html.html It's plastic, but fully pressure capable - has proper gas and liquid disconnect cap on top - something you don't get with the usual bucket fermenters. The plastic it's made of is meant to be very "non-porous" - shouldn't need much more than a rinse and a sanitise to be ready for the next brew. Will go to 30+psi safely - I'll keep it around 12 max. Beer will already be mostly carbed once it's kegged rather than having to worry about let it wait a week to take up the CO2. Fermenting under pressure is meant to let you go quicker, hotter and have keep the esters a non-issue. Larger at Aussie room temp rather than having to keep it as a mid winter brew should be an option. $129 plus another $40 or so for the pressure cap option. The bottle down the bottom lets you remove the trub/sediment mid brew (is a valve stopper) and also lets you add dry hops or finishers without exposing any of the brew to oxygen - remove bottle, empty crap, sanitise, purge with co2, add hops etc, reconnect, open valve. Lets you also take the yeast cleanly to harvest for a next brew. Going the pressure cap option it lets me keg the brew from the top rather than from the bottom - float and tube draw it from the top rather than draining it. Straight from fermentor to keg - no need to worry about secondary etc - all the crap stays at the bottom, only the good stuff is taken from the top. Got 4 19l Kegs 2nd hand and a 10l one. Also got a 4l "growler" (not all through "keg-king") That should give me a few beer options on tap at a time, the 10l for the "small batch"/experiments and the growler (about 12 stubbies) to take out the back or to a mates place - all of those filled under pressure, fully carbed and zero chance of degradation. Also got the nitro setup to run stouts etc - won't be an often thing, but the option will be welcome. (basically a different spout for the tap and a bottle/regulator for the gas) Nothing beats pouring a Guinness (I actually prefer nitro Kilkenny - which I'll be doing) properly. That's what made me give up - the "Beer droid" system only did 10l at a time and was a PITA to clean up and bottle. I'll use the droids moving forward to make my own "small batches" and also for the nitro stouts, porters and reds etc, but they'll be straight to the keg - zero secondary to carb up etc. Will also use the 10l's for random stuff like ciders, ginger beer and alco lemonade etc If you had an interest in brewing before - definitely look into it again with kegs. Cheap ($50??) local gumtree freezer, couple of taps ($20ea??), disconnects ($40??) fittings and lines ($$fark all), kegs ($40ea 2nd hand??) etc CO2 bottle and regulator you're all good As an early "brew my own" I reckon it'll cost me $20 a slab (to put it into normal speak) for my beer moving forward max - will get cheaper as I get better They'll also be quality/flavour of the slabs that are normally $60+ $20 for me to invite the mates round - pour cold beer off the tap - change kegs for a different brew etc. Damn - that'll be cheap (especially when I put up the "Tip-Jar $2 Pint" ) Thanks for all the info! Although brewing does interest me, I don't drink anymore. If I ever take it up again I'll know who to hassle with questions 1 Link to comment https://www.fordxr6turbo.com/forum/topic/81090-cool-stuff-you-just-bought/page/471/#findComment-1659164 Share on other sites More sharing options...
Rab WOT? Moderating Team 10,981 Member For: 12y 4m 11d Gender: Male Location: Frankston, 3199 Posted 18/06/18 12:56 PM Share Posted 18/06/18 12:56 PM 24 minutes ago, Renton said: Although brewing does interest me, I don't drink anymore. Give it time - you've only been on the forum a couple of months - you'll be reaching for a cold one eventually Link to comment https://www.fordxr6turbo.com/forum/topic/81090-cool-stuff-you-just-bought/page/471/#findComment-1659165 Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 12y 2m 5d Gender: Male Location: Western Sydney Posted 19/06/18 09:38 AM Share Posted 19/06/18 09:38 AM Sick of my ute being in peices, decided cooler pipes are getting done properly this time.Picked up a set of 3" plazmaclamps to go with the turbosmart 50mm BOVs. Getting the new cooler piping fabbed up later this week.Hopefully turns out kinda like this but 3" not 3.5". 6 Link to comment https://www.fordxr6turbo.com/forum/topic/81090-cool-stuff-you-just-bought/page/471/#findComment-1659205 Share on other sites More sharing options...
