  • You've changed man....
  • Member For: 14y 6m 5d
Showoff
Eeeeeeightyfive????
Edited by STAINOnegger
  • Member For: 19y 1m 5d
yes, the first type of Fuel I put through it was E85, actually it was E84.9 according to the readout.
Not quite working correctly at this point as I'm the first to have one of these set ups and a few bugs need to be ironed out, but already showed a fault with a fuel pump
  • Like 2
  • Member For: 16y 7m 11d
Pwwweeeeeese test all the united batches. I will even drop samples off weekly if I have to....
it is a on car tester, it test the ethanol content of the fuel being used, so is more accurate than taking a sample at the bowser because once it's in the tank it will mix with existing fuel and may change, it has proven to be more accurate than the test tube sampler I have used in the past, this shows E85 to be pretty much e85 while the test tube method shows in excess of 90%
It also shows fuel pressure while operating, even while doing a run, it shows fuel flowing in the feed line and also the return line which then a heap of math channels can be used to work out fuel flow versus fuel used, instant litres used and plenty more but the main one is it shows whether the fuel pump has been maxed, which is not always evident before hand as opening injectors longer can cover any lack of fuel delivery to a certain extent.
We've already proved that 1 x 044 was maxed at 400+ rwkw on E85, but it may have been a dud pump, but the owner has chosen to get a bigger pump to keep things safe
  • Like 2
  • FREAKY
  • Member For: 15y 6m 7d
hahah def showing off.
well done mick very nice.
So your the first to get one ey? intersting
yes showing off, it's a bit sad when my show off toys are to do with work :(
Mainline have had fuel modules available for a while, but have been working on the ethanol content part of it etc for a little while, This involved totally new module cabinet etc and yes I'm the first to have one installed, may not mean much at the end of the day, but it will give me more data information and you know what they say " information without data, is just an opinion"
  • Like 3
  • ...JD TUNING ADELAIDE...
  • Member For: 17y 1m 2d
yeh likeing your dedacation to doing a safe quality scale of work mick.
ralph fully imported? ........u can ( no pun) taste the differance lol
Very very exciting :) :)
u keep working if were ever gunna hold 1.7ltrs :P
