Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 4m 23d Gender: Male Location: Perth Posted 29/11/13 11:31 PM Author Share Posted 29/11/13 11:31 PM Is that the flex plate from your ZF? With a new stronger centre I'm assuming?Correct. It probably looks pretty similar to the one in your car Steve. Its a Nizpro plate. I doubt I would be able to make one for the price Simon charges. Link to comment Share on other sites More sharing options...
XtRmn8 570Nm @1800rpm Donating Members 2,441 Member For: 21y 4m 25d Gender: Male Location: Perth, WA Posted 29/11/13 11:59 PM Share Posted 29/11/13 11:59 PM Did you run out of welding wire.+1Looks like they replace the center with thicker stronger steel and spot weld it on?Ralph what is the ballpark supply figure for one of these? Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 4m 23d Gender: Male Location: Perth Posted 30/11/13 12:59 AM Author Share Posted 30/11/13 12:59 AM $285 plus frieght Link to comment Share on other sites More sharing options...
Kroozin Menace Donating Members 1,990 Member For: 13y 9m 25d Gender: Male Location: Sydney Posted 03/01/14 11:07 AM Share Posted 03/01/14 11:07 AM Link to comment Share on other sites More sharing options...
Kroozin Menace Donating Members 1,990 Member For: 13y 9m 25d Gender: Male Location: Sydney Posted 19/01/14 09:49 AM Share Posted 19/01/14 09:49 AM Maybe not that cool... yet Link to comment Share on other sites More sharing options...
Lennox Member 2,586 Member For: 11y 11m 20d Gender: Male Location: Perth Posted 19/01/14 10:56 AM Share Posted 19/01/14 10:56 AM (edited) ^ Raptor Supercharger kit. Edited 19/01/14 10:57 AM by Lennox 1 Link to comment Share on other sites More sharing options...
Kroozin Menace Donating Members 1,990 Member For: 13y 9m 25d Gender: Male Location: Sydney Posted 20/01/14 08:05 AM Share Posted 20/01/14 08:05 AM Up for some engine mounts.. Anyone ever used these?? Feedback http://bit.ly/1mt7Jli Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 2m 22d Gender: Male Location: Probably above atmospheric pressure Posted 20/01/14 01:25 PM Share Posted 20/01/14 01:25 PM (edited) Paging Ralph Wiggum...think he found them to be waaaaaaaaaaaay too solid and caused excessive NVH issues?Just read more on the ad and he talks them up for this actually:An extensive development program has made our Technico Torque Master Engine Mounts the smoothest and toughest poly bushed engine mounts available. Although they are about 60% stiffer than stock, they have been harmonically tuned to minimize vibration at idle and low engine speeds, yet are rated to withstand well over 1500 Nm of torque (over a 1000 BHP).These billet alloy, poly bushed engine mounts control torque by stiffening up the engine, constraining both its lift and movement. This increases the transmission of power to the rear wheels. It also significantly improves handling, because less movement of the engine means less weight shift and transfer. Control without the harness normally associated with stiff mounts. Edited 20/01/14 01:27 PM by -SteveR- Link to comment Share on other sites More sharing options...
Kroozin Menace Donating Members 1,990 Member For: 13y 9m 25d Gender: Male Location: Sydney Posted 20/01/14 11:12 PM Share Posted 20/01/14 11:12 PM Yeh I'm pm'd ralph and he said they were too noisy for him with the forgies and being a manual.. Which is the same combo I'd have. Glad I checked with him Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 4m 23d Gender: Male Location: Perth Posted 21/01/14 01:35 AM Author Share Posted 21/01/14 01:35 AM Everything John lists in his ad is true. They do transform the car. I actually had to reduce the rebound damping on my shock as the engine is tied in so well is doesn't act act a pendulum/counter weight moving side to side and up and down due independently to the chassis.In my case the combo of rattly forgies and near solid mounts was more than I could handle day to day. The transition from idle to around 1200 was the worst. I found and if i bumped the idle up to around 970 the vibes stopped at idle and the transitional vibration was greatly reduced.Unfortunately at that rpm point my old forgies liked to play their song loud and proud so in time it was more than I could handle.In a auto car or a car that gets tracked hard I would run them again in a heartbeat. 3 Link to comment Share on other sites More sharing options...
