Azid Member 213 Member For: 13y 7m 29d Posted 23/07/12 05:58 AM Share Posted 23/07/12 05:58 AM Hey guysI've rebuilt my car from ground up in new shell used same wiring looms and everything completely same stuff as came out of my other one when came time to power it up I got dash lights etc but no ICC power up. Any suggestions what could cause this? No offense to anyone but just people who actually have experience I don't want to hear things people have read and speak out about such as needs reprogramming from ford etcCheers guys Link to comment https://www.fordxr6turbo.com/forum/topic/81089-icc-power-up-issue/ Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 24d Gender: Male Location: Perth Posted 23/07/12 06:00 AM Share Posted 23/07/12 06:00 AM No power at all? Did you reseat the connector behind the ICC before installing it? Link to comment https://www.fordxr6turbo.com/forum/topic/81089-icc-power-up-issue/#findComment-1270124 Share on other sites More sharing options...
Azid Member 213 Member For: 13y 7m 29d Posted 23/07/12 06:04 AM Author Share Posted 23/07/12 06:04 AM What do u mean research it? The ICC has been out I put it back in yesterday it felt like it pushed back into the plug cleanly and the 4 plugs at bottom are in properly Link to comment https://www.fordxr6turbo.com/forum/topic/81089-icc-power-up-issue/#findComment-1270127 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 24d Gender: Male Location: Perth Posted 23/07/12 06:12 AM Share Posted 23/07/12 06:12 AM Reseat....you need to pull the white connector directly behind the ICC outwards until it clicks, then when you slide the ICC back in the alignment pins on it push the connector back and enagage the locks. Link to comment https://www.fordxr6turbo.com/forum/topic/81089-icc-power-up-issue/#findComment-1270133 Share on other sites More sharing options...
Azid Member 213 Member For: 13y 7m 29d Posted 23/07/12 06:14 AM Author Share Posted 23/07/12 06:14 AM Righto man cheers I'll give that a try when it stops raining hopefully it's a simple fix like that and not a deeper problem with wiring or computer Link to comment https://www.fordxr6turbo.com/forum/topic/81089-icc-power-up-issue/#findComment-1270136 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 24d Gender: Male Location: Perth Posted 23/07/12 06:17 AM Share Posted 23/07/12 06:17 AM if you dont reseat it, when you push the ICC back it can push the connector back and doesn't connect properly. Its hard to pick it because the small alignment pins on each side of the ICC (the gold colored ones that slide in on the dash frame) make it feel like it's settled home when the ICC may not have actually made contact. Link to comment https://www.fordxr6turbo.com/forum/topic/81089-icc-power-up-issue/#findComment-1270138 Share on other sites More sharing options...
Azid Member 213 Member For: 13y 7m 29d Posted 23/07/12 06:46 AM Author Share Posted 23/07/12 06:46 AM Righto buddy makes sense I've taken ICC out fair few times over the years and had no issues must have been lucky cheers man Link to comment https://www.fordxr6turbo.com/forum/topic/81089-icc-power-up-issue/#findComment-1270152 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 24d Gender: Male Location: Perth Posted 23/07/12 07:04 AM Share Posted 23/07/12 07:04 AM *no warranty on above advice tho! it could be an actual issue with the ICC Link to comment https://www.fordxr6turbo.com/forum/topic/81089-icc-power-up-issue/#findComment-1270161 Share on other sites More sharing options...
Azid Member 213 Member For: 13y 7m 29d Posted 24/07/12 04:22 AM Author Share Posted 24/07/12 04:22 AM yeah no worries ICC has been looked after and handled carefully s id be surprised if something was wrong with that. Could it be a computer issue? Im pretty positive the 2 same sized ecu plugs are in the right spot so shouldnt be an issue but not sure if ecu could cause it? Link to comment https://www.fordxr6turbo.com/forum/topic/81089-icc-power-up-issue/#findComment-1270491 Share on other sites More sharing options...
bionicxr6t05 Bronze Donating Members 2,216 Member For: 13y 9m 20d Gender: Male Posted 24/07/12 09:47 AM Share Posted 24/07/12 09:47 AM If the icc has power to it the screen should be on plain and simple... If there is a comms issue it will display code... Have you checked fuses and kickpanel connectors etc? Link to comment https://www.fordxr6turbo.com/forum/topic/81089-icc-power-up-issue/#findComment-1270556 Share on other sites More sharing options...
