Please How Do I Change Between Tunes On Capa Flash Box? Being Cautious
new370
  • Member For: 17y 1m 8d
Hi all,
I bought an xr6t which has been modified by Autotech in Sydney.
It uses the early capa flash tuning module which I have with the car, however ive forgotten what the seller told me about changing the selection of tunes. I dont want to select a tune and do any damage (the car was set-up so that in the highest kw tune it requires 'martini' fuel. As I am only running 98 octane fuel I am cautious about changing the tune to the high output without correct fuel. Maybe this isnt anything to be concerned about but better safe than sorry. I am not sure how to select the tune or if selecting this high output tune inadvertantly would cause any problem, so I havent touched it. Any advice on selecting different tunes would be appreciated as I cant get in touch with the seller. Thanks
  • Member For: 14y 5m 7d
  • Gender: Not Telling
I assume yo are taliking about the box flash tuner. But if not you will find what you need here anyway. As far as running your car on 98 with a Martini Race Fuel (102ron) tune, could end badly. The problem you have is knowing which number tune is the Martini. The logical guess would be the last tune port. Cheers
http://www.capa.com....ash_tuner_1.htm
Edited by Impellor
thanks for replying...
yes I am referring to the capa box. thanks for the info.
what does last tune port mean?
im also wondering if I connect the box will it indicate which tune it is currently set at so I at least know where it is before checking anything else?
thanks aagain for replying
  • Moar Powar Babeh
  • Member For: 19y 3m 4d
Call Mario at autotech and give him the serial number of the box/vin of the car. He should either be able to tell you exactly what tunes is in each slot, or tell you the normal procedure they use. IE 1 is Valet, 2 is 98, 3 is Martini
ok, thanks. ill do that tomorrow. appreciate your advice
