  • Waiting for the 1st N/A 12!
  • Member For: 17y 3m 16d
George is just soft, that's more the problem.
" my name is Vevapower and it has been 1 hour since I last boosted"
  • RNS10S
  • Member For: 18y 9m 11d
  On 19/07/2012 at 7:07 AM, xr6t_ute said:
I've never used the Nittos radials, but with the MT streets the pressures should be between 15-18psi, each cars different so find a setup that works for you.
What size are the Nittos?
It could also be sign there on the way out too.
Nittos are 275/45/17, car did not feel unstable in the top end so may take some pressure out next time.
  • Member For: 17y 11m 2d
Ive had 15psi in the 17s and its not unstable one bit, when you go to a full slick then you notice a difference.
Go straight to 18 and smash the ten.
22 is too high, but make sure you adjust the pressures when the tyre is hot.
Edited by xr6t_ute
  • Bronze Donating Members
  • Member For: 14y 1m 8d
Best 60ft I got 1.877 on just nt05 at 20psi on 19 u can go alot lower because of the higher profile on 17
I have found that nittos need alot of heat
Also are u getting wheel snip
Edited by Snapper
  • RNS10S
18 hot would be about 15 cold right Ivan?
  • RNS10S
Anything over 5psi boost and the tyres unload.
If I could take off at 6-7psi I would be happy.
Also 3-4 gear change is flaring and I have to lift off a tad for the gear to engage but I dont think its harming me too much
as the MPH is good.
  • RNS10S
  On 19/07/2012 at 9:07 AM, allmtr said:
I'd lend you my 255/60 ET streets but the rims won't fit over your brakes :(
Thanks Chuck but you are correct in that they will not fit, I have the larger rear brakes that are on the territory.
