rbjet Skid Machine Donating Members 1,640 Member For: 13y 8m 19d Gender: Male Posted 11/07/12 03:17 AM Share Posted 11/07/12 03:17 AM A 5 channel will be fine if you plan on ripping out the factory amp for the sub.I posted a link earlier in this thread to the jaycar sub which is a direct replacement.JB HI FI did mine. Link to comment Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 2m 21d Gender: Male Location: SE Melbourne Posted 11/07/12 03:23 AM Share Posted 11/07/12 03:23 AM isnt the audio 7 ch? or is there a high pass filter on the front speakers for the tweeters? Link to comment Share on other sites More sharing options...
webby324 Donating Members 313 Member For: 14y 7m 12d Gender: Male Location: Yarra Valley Posted 11/07/12 03:33 AM Author Share Posted 11/07/12 03:33 AM 7 ? how many does it need to run the sub ? I'll just ask the guys at JB I reckon they should know. Link to comment Share on other sites More sharing options...
rbjet Skid Machine Donating Members 1,640 Member For: 13y 8m 19d Gender: Male Posted 11/07/12 03:34 AM Share Posted 11/07/12 03:34 AM High pass filter. The front speakers are splits that run a little crossover. Similar to aftermarket component speakers. 1 Link to comment Share on other sites More sharing options...
rbjet Skid Machine Donating Members 1,640 Member For: 13y 8m 19d Gender: Male Posted 11/07/12 03:35 AM Share Posted 11/07/12 03:35 AM You need 4 channels to power all your speakers if you want to go down that path and you need another separate channel to power the sub. Link to comment Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 2m 21d Gender: Male Location: SE Melbourne Posted 11/07/12 03:37 AM Share Posted 11/07/12 03:37 AM Link to comment Share on other sites More sharing options...
webby324 Donating Members 313 Member For: 14y 7m 12d Gender: Male Location: Yarra Valley Posted 11/07/12 03:40 AM Author Share Posted 11/07/12 03:40 AM Righto then so 5 in total, sweet, cheers rb 1 Link to comment Share on other sites More sharing options...
Shyfrd Turboless Donating Members 5,992 Member For: 13y 11m 15d Gender: Male Location: Geelong, Victoria Posted 11/07/12 03:47 AM Share Posted 11/07/12 03:47 AM Ive got the standard stereo, no premo biznizz. Running a line out converter in the passengers kick panel. Ran rca's down the rear for speakers and sub but atm only running a monoblock class d (I think) alpine and a second hand pioneer sub. The sub is aging and lets it down but its enough for now. Got rca's run up to the rear ready for an amp and speakers but probably wont do it.The amp is mounted a bit trick, on some mdf and bolted upside down under the parcel shelf with the carpet cut out perfectly to just see the amp and no wiring or mdf. Sub box is just the right height and fits neatly between amp/back seat. Doesnt nove a cm!Next car I get ill be doing a full stereo upgrade and dynamat etc. Burger with the lot pretty much Link to comment Share on other sites More sharing options...
Kroozin Menace Donating Members 1,990 Member For: 13y 9m 21d Gender: Male Location: Sydney Posted 11/07/12 03:59 AM Share Posted 11/07/12 03:59 AM did yours have Premo sound Brendan? Mine doesn't so I'll have to mount an amp and use the rear speakers for input. :/I swapped the fronts for Kicker splits ($180 from ryda.com.au) and mounted the tweeters in the doors, which actually made a massive difference over the factory cardboard speakers.I'll swap the rears to Kicker non splits ($80) and add the sub which will be fine I think, I don't crank music these days anyway.Better late then never... yeh mate mind has the premo sound but I threw the 8" in the bin, the rest is still factory. What would happen if ya fitted another HU and ran new speaker wires to your existing (or upgraded) speakers fed from an amp splicing into the cables that are already coming from your factory icc. Bare with me... would you be able to run either the icc unit or your aftermarket head unit?This way if the misses jumps in she could use the factory setup thereabouts and I could use the aftermarket setup.May need to reword that, probably doesn't make any sense.. Link to comment Share on other sites More sharing options...
Ciaran Thooperrrrrrr Donating Members 2,768 Member For: 13y 7m 9d Gender: Male Location: NOR, Western Australia Posted 11/07/12 04:53 AM Share Posted 11/07/12 04:53 AM In other words, can you wire it to use both ICC and aftermarket unit?Maybe have like a switch in there that flicks between the 2? 1 Link to comment Share on other sites More sharing options...
