MBAF Bronze Donating Members 2,156 Member For: 8y 10m 7d Posted 01/09/19 12:50 PM Share Posted 01/09/19 12:50 PM (edited) It’s not bad but the Bowdens stuff is way better and more readily available Edited 01/09/19 12:55 PM by MBAF 1 Link to comment https://www.fordxr6turbo.com/forum/topic/80918-what-did-you-do-to-your-car-today/page/979/#findComment-1688012 Share on other sites More sharing options...
bossmang FREAKY Donating Members 12,440 Member For: 15y 5m 28d Gender: Male Location: Melbourne Posted 01/09/19 12:54 PM Share Posted 01/09/19 12:54 PM yer go the bowdens stuff 1 Link to comment https://www.fordxr6turbo.com/forum/topic/80918-what-did-you-do-to-your-car-today/page/979/#findComment-1688015 Share on other sites More sharing options...
Slowxr6t Member 587 Member For: 6y 6m 18d Location: New zealand Posted 02/09/19 08:15 AM Share Posted 02/09/19 08:15 AM Today I installed atomic oil pump with my mechanic and he showed me how to change valve springs and I'm doing them today and tomorrow, the collets are fiddly little sods but a bit of grease is the trick to stick them to screwdriver when installing the collets. Iv changed 8 springs so far working from front to back and really not looking forward to doing back springs, I'm using atomic tool. Link to comment https://www.fordxr6turbo.com/forum/topic/80918-what-did-you-do-to-your-car-today/page/979/#findComment-1688045 Share on other sites More sharing options...
BeerTurbo Donating Members 241 Member For: 7y 1m 13d Posted 02/09/19 08:17 AM Share Posted 02/09/19 08:17 AM once you get to the back ones you should be pro, be able to do them blind, which is basically what you have to do anyway. Link to comment https://www.fordxr6turbo.com/forum/topic/80918-what-did-you-do-to-your-car-today/page/979/#findComment-1688046 Share on other sites More sharing options...
Slowxr6t Member 587 Member For: 6y 6m 18d Location: New zealand Posted 03/09/19 06:38 AM Share Posted 03/09/19 06:38 AM Well today I got back into changing valve springs, all was going well until I got to exhaust valve on cylinder 4, I started winding bolt down to compress spring and I heard valve pop off seat and it started to pass a bit more air, I got collets off and when I put new spring on and started to compress it to get the collets on, the valve was going down as well and it would come up again when I unwound tension off the spring, I tried a couple of times then took spring off. Anyway I touched the top of the valve stem with my finger and it decided it would glide off down into the cylinder. Now I have a problem, I cant see it thru exhaust port. My engine builder said I should have had each cylinder at tdc when doing each cylinder. Was prepared to pull off head and change head bolts to arp bolts, new head gasket, but I'm gonna try turn crank slowly so piston comes up and try retrieve valve with magnet and try poke it back up valve stem first. No one told me to have each cylinder at tdc so if a valve drops it cant go far. Also if the piston is down the cylinder is a big area to fill with air and it's harder for the air to hold valve up, makes sense!! All was going so well too, damn it. Link to comment https://www.fordxr6turbo.com/forum/topic/80918-what-did-you-do-to-your-car-today/page/979/#findComment-1688071 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,566 Member For: 17y 2m 12d Gender: Male Location: Melbourne Posted 03/09/19 06:41 AM Share Posted 03/09/19 06:41 AM ouch... hopefully you can get it out. Link to comment https://www.fordxr6turbo.com/forum/topic/80918-what-did-you-do-to-your-car-today/page/979/#findComment-1688072 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 7m 26d Gender: Male Location: Perth Posted 03/09/19 06:49 AM Share Posted 03/09/19 06:49 AM (edited) Has it definitely dropped out. ?? Check before turning crank. If air hasnt come up through guide it's still in the guide. Magnet down the guide. Slow down. It can get expensive quick. Edited 03/09/19 06:53 AM by arronm Link to comment https://www.fordxr6turbo.com/forum/topic/80918-what-did-you-do-to-your-car-today/page/979/#findComment-1688074 Share on other sites More sharing options...
Slowxr6t Member 587 Member For: 6y 6m 18d Location: New zealand Posted 03/09/19 07:25 AM Share Posted 03/09/19 07:25 AM Its definitely in cylinder, no valve to be seen thru exhaust port, I turned crank lightly clockwise a little bit and it stopped, I think piston may be binding on valve. Link to comment https://www.fordxr6turbo.com/forum/topic/80918-what-did-you-do-to-your-car-today/page/979/#findComment-1688077 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 7m 26d Gender: Male Location: Perth Posted 03/09/19 08:04 AM Share Posted 03/09/19 08:04 AM Valve length is greater than piston width. So..... Link to comment https://www.fordxr6turbo.com/forum/topic/80918-what-did-you-do-to-your-car-today/page/979/#findComment-1688081 Share on other sites More sharing options...
Slowxr6t Member 587 Member For: 6y 6m 18d Location: New zealand Posted 03/09/19 08:37 AM Share Posted 03/09/19 08:37 AM Cool, so it shouldn't bind? Valve hole is 5.5mm, can you buy long magnets that thin? Link to comment https://www.fordxr6turbo.com/forum/topic/80918-what-did-you-do-to-your-car-today/page/979/#findComment-1688086 Share on other sites More sharing options...
