  • Dropping a turd
  • Member For: 17y 7m 22d
  On 04/06/2019 at 11:34 PM, Puffwagon said:
Dindu nuffin today but since I put the 4 inch turbo intake on, it's started sucking oil out of the rocker cover through the breather hose, on decel after boosting.
I spose a rocker cover mod or a catch can arrangement is in order.
Expand
I bet it's sucking through pcv valve.  Just throw catch cans on both circuits.   The pcv is the worst.
  On 05/06/2019 at 12:08 AM, BeerTurbo said:
rocker off, might as well do the valve-springs, might as well bolt in some head studs, do everything.
Expand
Rocker off. Check cam lobes.
  • Member For: 6y 6m 14d
Took off plastic rocker cover guard to see what the story is to weld on some big dog Earl's 15mm I d 90 degree bends onto breather outlet and pcv outlet to run some 19mm push loc hose to a catch can and vent it to under the car with a length of 32mm vacuum cleaner hose that bends round corners quite nicely. The can will be passenger side up by firewall. The breather vent hole on the rocker cover is a small 10mm or so and the pcv hole is a big 20mm ish. I will take rocker cover off and drill out the breather hole then get an engineer to tig on the alloy fitting to the rocker cover and the Earl's bend screws on it once plastic cover is back on top. Luckily there's plenty of room between the top of engine and bonnet to fit these fittings. The beast will be free to breath with no crap pcv to worry about. Simple as! We can get away with this in nz.
  • Member For: 9y 10m 17d
Scored some BA XR8 18’s for cheap with decent tyres 7mm plus. Always good to have some rims spare that clear brembos.
  • Like 2
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 2m 8d
washed it for the first time in ages since it'd been raining pretty much a bit every day for ages :)
