  • Is on holiday from communism
  • Member For: 6y 5m 19d
  • Gender: Female
Why does mine look different?
Edited by I love kittens
Cause its funny
  • To Loud
  • Member For: 13y 6m 22d
That looks like some sort of sexual device.
I am now worried about you.
  • Thanks 1
  • Gender: Female
Re did some vacuum lines:turboboink:
Have I put the brass T piece for a boost/vacuum signal here. Is that right? Can't see anywhere else I can put. I'm not really a big fan of it because the fuel pressure regulator runs on the same Y piece. I know I can run the line for the boost gauge anywhere on the piping near the throttle body. I'm just asking if it's good where it is now.
Because I dont want to buy a new blow off valve and will have to re run vacuum lines depending on answer for next question.... As the car sits now the standard Bosch BOV leaks air at idle because there's nothing on the outlet side helping it close under vacuum because it doesn't have the crossover intake anymore.  Instead of buying a new standard unit or a aftermarket one because I believe the one I have now is faulty,  I would like to know if people that have had their car tuned if their tuners have removed the standard blow off valve all together.
Car is auto, FG. Standard turbo, not planning on going over 300rwkw and it's a daily so will rarely see WOT and full boost
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 2m 11d
Expand
This is the way to go. Just remove it. There's no worries doing so.
It shouldn't have trouble staying closed as it only opens when it has a vacuum source. Just make sure it either re-circulates the air to the intake or has a mini filter on it, if you want to keep it.
  • Thanks 1
  • Gender: Female
Yeah but as it sits now, when I unplug the vacuum line the diaphragm snaps closed and when I put it back on it slightly opens. Either the spring is snagged or its designed to have a bit of vacuum from the over the engine intake like it would if it was standard to stay fully closed. Looks and feels like a sensitive blow off valve.
I'll just remove it before it gets tuna'd
  • Member For: 10y 4m 23d
  • Gender: Not Telling
Fitted me under the battery intake today. More stuffing around than I thought it would be but whatever. Had to retune it as it was hitting boost cut and leaning out a tad but all good now though. The iat's are much better but it is a fair bit colder tonight with 22c ambient.
#choochoo
Here's a half assed pic.
  • Site Developer
nice work, puffster :) how big is the pod, if it fits up behind the massive space under there? lol
