Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 5d Gender: Male Location: Perth Posted 29/05/17 11:00 AM Share Posted 29/05/17 11:00 AM I hadn't seen that question, if the thread is munted and jams before compressing the gasket to the point it'll seal then the only fixed is to fix the thread. Otherwise a sly washer on the bolt may give enough compression before it jams. Either way paper gaskets in an area that sees as much heat as a turbo drain is testicles and a high temp oring arrangement will always be better 1 Link to comment https://www.fordxr6turbo.com/forum/topic/80918-what-did-you-do-to-your-car-today/page/842/#findComment-1640068 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,439 Member For: 17y 18d Gender: Male Location: Melbourne Posted 29/05/17 11:02 AM Share Posted 29/05/17 11:02 AM Fair enough. Thanks for that I'll give the washer a try - not optimistic haha. Link to comment https://www.fordxr6turbo.com/forum/topic/80918-what-did-you-do-to-your-car-today/page/842/#findComment-1640070 Share on other sites More sharing options...
eff xr6t Member 569 Member For: 11y 6m 29d Posted 29/05/17 11:35 AM Share Posted 29/05/17 11:35 AM Should be able to helicoil easily in that area? Easy fix being a small bolt in aluminium also more room there on a B series k frame then my E series. Link to comment https://www.fordxr6turbo.com/forum/topic/80918-what-did-you-do-to-your-car-today/page/842/#findComment-1640071 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,439 Member For: 17y 18d Gender: Male Location: Melbourne Posted 29/05/17 11:40 AM Share Posted 29/05/17 11:40 AM yeah, there's a bit of room, if you can maneuver around the hot side pipe unfortunately I don't own a helicoil kit. Link to comment https://www.fordxr6turbo.com/forum/topic/80918-what-did-you-do-to-your-car-today/page/842/#findComment-1640072 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 6m 1d Gender: Male Location: Perth Posted 29/05/17 11:43 AM Share Posted 29/05/17 11:43 AM (edited) You buy them at the shops crack boy. I look at cracks all day. And sometimes at night Edited 29/05/17 11:46 AM by arronm Link to comment https://www.fordxr6turbo.com/forum/topic/80918-what-did-you-do-to-your-car-today/page/842/#findComment-1640073 Share on other sites More sharing options...
bupalooga Silver Donating Members 261 Member For: 12y 6m 22d Gender: Male Location: Griffith NSW Posted 29/05/17 11:43 AM Share Posted 29/05/17 11:43 AM Forgot to post what I got done over the weekend:Rear wheal bearing replaced, thanks heaps to bamk2f6tornado for very accurate instructions for the procedure. Cold side & core from 2nd hand snail attached to the old modified hot side & wastegate & remounted with new studs. Air system for horn & bagged trailer all finished & works posh as! Switches to control it all from the cabin. It's a bit hard to show the horns cause they're crammed right up under the tray, so these are the best pics I can get. & finished up the weekend with a fully hectic clean & Polish. Sent from my fancy pansy touchy screeny phoney using a Tapatalka appliacationa 5 Link to comment https://www.fordxr6turbo.com/forum/topic/80918-what-did-you-do-to-your-car-today/page/842/#findComment-1640074 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,439 Member For: 17y 18d Gender: Male Location: Melbourne Posted 29/05/17 11:46 AM Share Posted 29/05/17 11:46 AM On 29/05/2017 at 11:43 AM, arronm said: You buy them at the shops crack boy. Expand derp... it would cost me less to get the mobile thread guy around to fix it than it would to buy a helicoil kit. Link to comment https://www.fordxr6turbo.com/forum/topic/80918-what-did-you-do-to-your-car-today/page/842/#findComment-1640075 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 5d Gender: Male Location: Perth Posted 29/05/17 11:46 AM Share Posted 29/05/17 11:46 AM Honk.... Link to comment https://www.fordxr6turbo.com/forum/topic/80918-what-did-you-do-to-your-car-today/page/842/#findComment-1640076 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 5d Gender: Male Location: Perth Posted 29/05/17 11:54 AM Share Posted 29/05/17 11:54 AM Is the munted thread in the sump? If so bulk room to helicoil it. Plug the drain hole with rag first and don't drill all the way through. The holes are blind from the factory. Link to comment https://www.fordxr6turbo.com/forum/topic/80918-what-did-you-do-to-your-car-today/page/842/#findComment-1640077 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,439 Member For: 17y 18d Gender: Male Location: Melbourne Posted 29/05/17 11:55 AM Share Posted 29/05/17 11:55 AM yeah, it's in the sump. cheers guys, appreciate it Link to comment https://www.fordxr6turbo.com/forum/topic/80918-what-did-you-do-to-your-car-today/page/842/#findComment-1640078 Share on other sites More sharing options...
