  • Moar Powar Babeh
  • Member For: 19y 8m 29d
  On 24/05/2017 at 9:14 PM, ScatterBrain said:
my old gtx3582 for reference.
Expand
What spec rear housing?
Got a boost v rpm plot?
I've got an s364.5-sxe on my F6 and love it.
#datspool
  • Member For: 16y 20d
The rear housing is a modified .82 internally gated efr9180 housing, with the 80mm turbine wheel it flows just a bit more then the stock 1.06. By my calculations the choke threshold would be around 700 to 720 rwhp.
Boost curve for second last dyno pull, Gtx3582r (Green) vs s369 (Red)
  • Like 2
  • ...JD TUNING ADELAIDE...
  • Member For: 17y 21d
Hummm so what was the point of the bigger turbo ?
at 470rwkw (630hp) the Gen 1 GTX82 is more than capable of producing that at 22psi with the obvious quicker spool time
the talk that ball bearing over journal bearing is only 1/10th quicker spool speed so it's negligible but why did you effectively want a laggier turbo as it couldn't be from just the power generation but are you chasing grip or something ?
Basically for better efficiency. Yeah sure a gtx3582 can make 630hp @ 22psi but not as safely as the sx369. If you glace at the post above you'll see the AFR is around 11.6, If I was the lean it out to around the 12.4 which is about the average for a lot of tunes, it would make a reasonable bit more power. But as my car is setup for circuit racing and I have longevity in mind, I have opted to keep everything on the safe side, Timing included. On top of that not having a water cooled core means less heat it to the cooling system.
  • Member For: 11y 8m 22d
That power graph makes me very happy will probably order one in a couple of weeks. After comparing mine and a mates car mine gt3788r .89 rear ball bearing vs 6766 1.15 journal bearing the 6766 is 10 times better for response then my ball bearing even with larger wheels and huge rear housing. Looking at a powergraph overlay on the dyno my car comes on earlier and builds boost faster but on the street my car has a lot more transient lag when stomping on the throttle from high rpm. Will bang journal 6766 again before garret tractor.
Expand
And all very valid points mate :)
ive never been involved with a circuit set up falcon but as you've shown it's no small challenge keeping a 4000lb barge cool and repeatable going around for minutes on WOT vs a 400mtr sprint that we're all very used to seeing
  • XR50T
  • Member For: 12y 1m 20d
Small turbos run hotter freaky, falcons overheat easy at the track.
