  • To Loud
  • Member For: 13y 7m 8d
It looks mint with the leather seats.....
Maybe change the gear boot to a cream leather one and it would look better??
Did you put cv grease on the gear knob too see what black would look like?
Edited by masda74
  • Bronze Donating Members
  • Member For: 11y 7m 5d
Might be an idea if the suede ever sh*ts the tin. Haha na from taking it in n out of gear to do the Cv bolts up with grease covered hands
Been a quiet week due to all this water about. Got a bit done today
Trimmed the inner tub lip and hammed the lip Flat. Should allow for 295 wide rubber hopefully. (Pic pre paint)
Shocks installed with new bushes
Put the tub back on then started on this fuel system. Ran a few lines then called time for a beer. Hopefully get it finished up this week. The urge for a skid is strengthening c3e2cd58f23a3d444a920456093ae90a.jpg7188535d519a424a8e1edd9aac017a0d.jpg02c1b39071440b69e93196e04d7c4636.jpgb672318770443ca28d3832eada3da193.jpg
  • Like 4
  • Feeling the Love :-)
  • Member For: 12y 3m 7d
it' that time again.
of course I can't just buy oil and a filter.
interested to see how good the "fully Slick" goes
  • Like 2
Got the tub all bolted in. Wires n fuel lines all ran. Nutserted all the bolts that hold the tub liner in and hardlid on for a neater finish. Have some nice stainless eyelets go in there for easier load restraint.
Pro tip- when making a cheap nutsert tool make sure you don't use a sharp bit of steel haha. Almost spent my arvo at the doctors. Hopefuly have it finished tomorrow fingers crossed 5a1605a2d0ccda88a844a09ed7b58c69.jpg945e06d0e2ae1c903cfb8ed38fc2e00f.jpg3e4ed7561ba49ee40429389f4532653f.jpg23d1dc79d0315c509e945e8d9094e1e1.jpg8688935338879a71293832e4c8b539c0.jpg
  • Like 3
Got the Ute finished today. Finished up all the wiring. Both the 044 and the walbro intank now have there own relays triggered from the stock pump wiring (inertia/roll-over switch will shut pumps off still).
Going to put a cover over the relays eventually by won't really matter once the hardlid goes on.
Gave it a much needed wash.
Had 1 minor f*ck up. I was wondering why the Ute wasnt idling and 044 was making bulk noise and stuttering. After much confusion I ended up having the feed/return lines back to front on the chassis rails. So swapped em round and hooked it all back up and it ran perfect.
Deleted the stock filter so now it just has the earls one in the tray. Used a male and a female 5/16th hardline adaptor.
And most importantly took it for a spin! Been atleast a month since its seen boost. The shocks are much nicer now softened up. The swaybar makes a noticeable different, feels much more positive.
Tramp rods work mint. No binding noises. No skids yet but gave it a stab in second and it just lit them up with no tramp what so ever. Beer time 22ee4e6d9e9fe617a202c7f8eb94e284.jpgaaebfc913f0e53583ddbf23412cc042c.jpg4ba4997be55ca7836c4b86d870e6a6f8.jpg
  • Like 9
  • Member For: 12y 9m 3d
Going to be removing the diff hat on the FG turbo ute this weekend to re-seal. Its been leaking from the top of the hat, never dripping in the driveway but always wet with oil over so I'm assuming its coming from the top while I drive.
Any suggestions on gasket goop? new oil? additives? cleaning out the diff? what to check for while I'm there?
The permatex red sealant is pretty good. They also make a special green one designed just for diffs. That's not bad if you can find it. Have that on mine and not a drop spilled. Just give it time to cure before you shove oil in there.
While your under there check your diff breather hose isn't cracked/blocked.
Take the Ute for a drive before your drain the diff to get it nice n hot so all the old oil comes out.
No need for additives if you use a decent premium synthetic oil. The penrite stuff below is pretty good for a stock diff. While the covers off you may aswell check for wear on the crown (missing teeth or uneven wear) bbd192ec5c1ac3d7fad0e5ce61b9215a.jpg
  • Like 2
