Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 7m 2d Gender: Male Location: Adelaide Posted 04/11/15 09:18 AM Share Posted 04/11/15 09:18 AM How the fark do you do it in 20mins gaz. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,292 Member For: 16y 10m 26d Gender: Male Location: Melbourne Posted 04/11/15 09:20 AM Share Posted 04/11/15 09:20 AM Still looks farked with the bolt hanging out that far. Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 7m 15d Posted 04/11/15 09:53 AM Share Posted 04/11/15 09:53 AM Bolts all the way home. The bush is a non Ford item and it's a bit thicker so sits out further. Easy as biz. Crush your spare wheel well 10mm by using a car twist Jack then there is enough room to slide the bush in at an angle, fit the bolt into the bush, then twist it all into position. 2 Link to comment Share on other sites More sharing options...
.Stripes. All stock bar the k&n panel filter Silver Donating Members 8,061 Member For: 12y 11m 23d Gender: Male Location: Perth Posted 04/11/15 10:55 AM Share Posted 04/11/15 10:55 AM (edited) ^ Ralph suggested something similar to me a couple years back. Although his advice as to use the bolt to lever the bush in and out. Worked a treat for me! Edited 04/11/15 10:56 AM by .Stripes. Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 7m 15d Posted 04/11/15 11:52 AM Share Posted 04/11/15 11:52 AM Yeah it's a dream once the stock bush is gone. Getting the bush in is easy. Getting the bolt through that is the hard part. Link to comment Share on other sites More sharing options...
Rab WOT? Moderating Team 10,981 Member For: 12y 11d Gender: Male Location: Frankston, 3199 Posted 04/11/15 08:36 PM Share Posted 04/11/15 08:36 PM Link to comment Share on other sites More sharing options...
wagondad New Member 20 Member For: 10y 2m 26d Gender: Male Location: Mandurah W.A. Posted 05/11/15 02:05 AM Share Posted 05/11/15 02:05 AM Fitted a second hand, freshly painted and insulated Blue Power intake. Modified to keep using original cold air intake. While I was at it, removed the pipes to the turbo and heat shielding and checked all manifold and turbo bolts, only had to tighten three bolts at the rear of the exhaust manifold. Link to comment Share on other sites More sharing options...
bamk2f6tornado Bronze Donating Members 777 Member For: 11y 3m 5d Gender: Male Location: Rockhampton Qld Posted 06/11/15 10:04 AM Share Posted 06/11/15 10:04 AM Raised my Hurst shifter up about 5cm from the malwood shifter. Just made a extension with some 6mm ally plate. 1 Link to comment Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 11y 10m 7d Gender: Male Location: Western Sydney Posted 06/11/15 10:21 AM Share Posted 06/11/15 10:21 AM Fitted a new 32mm fenix radiator. Best fitting aftermarket rad for the fg and very well priced. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,292 Member For: 16y 10m 26d Gender: Male Location: Melbourne Posted 06/11/15 10:24 AM Share Posted 06/11/15 10:24 AM Raised my Hurst shifter up about 5cm from the malwood shifter. Just made a extension with some 6mm ally plate.Did you get that whole setup from malwood?I want to get a Hurst shifter and shaft... Link to comment Share on other sites More sharing options...
