What Did You Do To Your Car Today?
Henz
  • Dropping a turd
  • Member For: 17y 4m 11d
ah you know, just your normal Saturday morning in the shed
0c6UvJH.jpg?1
It may not be as effective as you think. Make sure you use the correct procedure for tightening and loctiting the flywheel bolts...
  • Member For: 12y 2m 2d
Wow... That really sucks. How much power was that car making arronm? And what was the benefit of using hollow dowel pins instead of solid??
  • Dropping a turd
You would have to ask nizpro that, but as they are internally threaded easy to remove. How do you intend to get yours out if needed. You do realize they need to be an interference fit..
Yes we did take all that into consideration. Once you remove the flywheel you will have enough dowel pin exposed to pull them out if needed. Hollow dowel pins wouldn't be my first choice in this situation. Shear stress is measured from force and cross sectional area. Obviously the hollow pins will have less cross sectional area which results in higher shear stress. The dowel pins we used are solid diam 10 precision machined, heat treated din6325 standard with a m6 tolerance. We used an imperial drill size 25/64 which is 9.92mm. The dowel pins are 10.006mm - 10.015mm
  • Moar Powar Babeh
  • Member For: 19y 5m 15d
0c6UvJH.jpg?1
I starting to understand why the nizpro car doesn't get driven much.
  • Like 2
  • less WHY; more WOT
  • Site Developer
  • Member For: 16y 11m
Flywheel bolts procedure? Other than heat resistant loctite and tightening the bolts in the correct order slowly, what procedure is there?
  • Dropping a turd
If you need to ask best stick to auto.
