What Did You Do To Your Car Today?
Henz
  • Member For: 11y 29d
changed oil and filter .I also changed the brand of filter , from a fibreglass filled baldwin (made in usa ) to a KN made in Korea (paper filter only) I also went one grade higher from 15-50 to 20-60 . so far have not noticed any difference only that my oil pressure at idle is about 5 psi more .next oil change I will go back to the baldwin filter ,they are way better made
just thought to go the extra thick oil ,as I will be going to powerplay on the 7 February .(and it will get very hot ). I hardly drive the car now ,will definitely let the engine warm up well before I give it a hard time so that the oil has time to warm up as well .
  • Member For: 11y 5m 4d
Took the inlet manifold off, found most of the bolts were loose and the gasket came out in 4 pieces... Getting the wiring loom out of the way was a massive pain for sure!
Also got pictures of the inlet side and looks pretty good for a car with 220k on it.
Inlet to the 3rd cylinder
Edited by Serangan
  • Moar Powar Babeh
  • Member For: 19y 5m 3d
I had to replace the engine loom in my ba, I wound up cutting off the casting bridges between each runner and filing them smooth. made it much much easier to slot the loom back in.
  • I <3 Floods
  • Member For: 13y 6m 25d
I discovered that Nulon Brake cleaner removed remaining plasti-dip from wheels really well..
And once that was discovered I went and purchased a bag of rags from supercheap..
Then I thought about cleaning the rest of the wheels..
1 clean.. 1 partly cleaned.
Put it all back together today. New intake gasket, fuel pressure regulator and serpentine belt. Also re-ran some wiring while I had easy access and installed new process west cross over pipe. much happier with it now.
