  • 570Nm @1800rpm
  • Member For: 21y 9m 11d
Started out by pulling passenger door trim off to find a rattle that been there for 2 years, which should have been a 30min fix and ended up in the garage for 6 hours.
Ended up doing the following:
- Pulled all door trims off and addressed some common FG build quality issues when it comes for poorly assembled door trims that results in rattle and squeaks. (there is a good thread in the AFF FG section about this)
- While I was at it, called the missed who was out to swing past Jaycar and grab me a few packs of sounds deadening. Installed sound deadener to inside of all 4 door skins.
- Had a set of front and rear Pioneer speakers I impulse bought many moons ago that have been sitting in boxes collecting dust, so whipped up some MDF spacers and fitted them up.
Put the car back together and after lunch, though while I was at it I would take my wheels off to clean and inspect them and also re-bleed the brakes. After fitting the upgraded brakes over xmas I was not 100% convinced the one man bleed kit I used was that great.
So off came the back wheels for a thorough clean and bleed the rears using the trusty old two man bleed method. Bled about 200ml of fluid through each rear caliper and both had small amounts of air in the lines. Repeated the process at the front and only the passenger inner nipple showed a few very small air bubbles. Bleed another 200ml though each front Brembo caliper and put is all back together.
6 hours later took it for a drive and good results all round. Doors feel a sh!tload more solid and no more rattles in the door trims plus there is less road noise in the car. The Pioneer 2ways that replaced the factory premium Pioneer paper speakers sound a lot better too. A lot more clarity and do not distort like the factory speakers did.
Brakes feel better too and I just better knowing that they have been done properly :) ............good days work in the garage while it pissed down outside all day.
  • Like 3
  • Member For: 11y 5m 5d
does it move forwards and back ? mine did ,and it had a cracked bearing housing .it also moved up and down but not enough to scrape .the turbo guy said I just got it in time .spyathe how many klm on the clock .mine only had 108000 klm on the clock ,and it was stuffed .just replace the oil line mate its well worth it .your oil pressure guage will not read the turbo oil line psi ,the turbo is after the sensor .
even my rebuild core has some movement but not forwards and back .best of luck mate
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 2m 23d
It definitely shouldn't be making a scraping noise like that, Spyathe... time for a new core... you can get it from ebay for approx $900 (from the US, I think)... I believe that the CHRA part number is 706451-0005
  • Dropping a turd
  • Member For: 17y 8m 6d
XR6 turbo freespin: http://youtu.be/a7JNOvigLLQ
That core is rooted. Dont drive it anymore. If it hasnt scored the housings only new core. To check for oil take off line and put in 2L icecream container.
Have a friend hold the accelerator flat to the floor and crank the car over in 5 - 10 second bursts. Oil should start to gush out after the second or third time. No oil means blocked filter or coked line.
DO NOT TAKE YOUR FOOT OFF THE ACCELERATOR WHILE CRANKING OR THE CAR WILL START.
  • Like 4
  • Dropping a turd
The tink noise you hear is the balls hitting one another. The cage has collapsed. Dont drive or even start. You maybe lucky and only CORE.
