What Did You Do To Your Car Today?
Henz
  • Member For: 15y 10m 24d
#96 - you need to re aim the headlights when you do a hid conversion, as the bulbs are different shape and size to a standard h4. You willbblind people otherwise.
agreed, you will get flashed alot if you dont adjust them, would hate to blind a copper...
  • Member For: 11y 11m 6d
will see how they go come dark tonight, but the bulbs looked damn close.
where the hid lights from (not exactly a filament, but yeah, anyway) has a shield on the lower 180deg, just like the H4. it also appears to be mighty close to the same distance from the mounting part of the light. when you switch over to high beams, to prevent having to have the bulb warm up again, the bulb moves back about 5-10mm, into the same spot that the second filament is located on the original H4 bulbs.
hoping they don't annoy everyone, but time will tell...
  • less WHY; more WOT
  • Site Developer
  • Member For: 16y 6m 22d
Yeah, I've installed heaps of HID's in B and F series falcons. Every single time you had to re-aim the headlights down, as they end up slightly higher without any adjustment at all. I know all about the shielding and the highbeam solenoid movement :) Those relays and ground points rust if you don't isolate them well.
It's not too hard to adjust. Just get somebody with correctly adjusted (standard) globe positions, a relatively new car is preferable with this, and compare facing a wall on level ground at an even distance from the wall. Find the "bright spot" on the other persons headlights, match the bright spot of your headlights against that.
Personally, I put HID's just a touch below stock headlight height as HID's are so much brighter and reach further than halogens by default.
you can if you have a mate with a dad with a workshop, a carton of jacks for payment, and about an hour and a half spare. We didn't bother with the 2nd one, paid a tire shop to do that. was a bit more difficult than they expected :sarcastichand:
  • Thooperrrrrrr
  • Member For: 13y 3m 30d
Blocked off BoV ports so it flutters.
Sounds good, had previously vented it but didn't like the continuous pshhhhhhhhhhhhhhh sound that just kept going and going. Now its Tutututututu and sounds much better
  • blind leading the blind
  • Member For: 16y 1m 21d
Nah probably a Polaris rzr. Getting a work vehicle with the new job so utes going. Not happy but what can you do
  • Member For: 16y 11m 7d
Flutter FTW, even on stock BOV but triple the factory boost muahaha.
  • Member For: 15y 9m 11d
My car only had a G6E badge on it...missing the "turbo", so took it off and ran the car badgeless.......changed my mind and wanted a badge back on so stuck on a G6E Turbo badge, with the TURBO in black lettering instead on the red.
AFAIK the black "turbo" lettering only came on the red (seduce) cars.
