ms700 Moderating Team 10,170 Member For: 22y 4m 18d Gender: Male Location: Sydney Posted 02/11/12 05:45 AM Share Posted 02/11/12 05:45 AM who's jetsnot?is that j@? Link to comment https://www.fordxr6turbo.com/forum/topic/80918-what-did-you-do-to-your-car-today/page/146/#findComment-1319411 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 4m 11d Gender: Male Location: SW Sydney Posted 02/11/12 05:46 AM Share Posted 02/11/12 05:46 AM It's just a standard one mate, nothing too flash. 90 clams through trade discount at Rocket Industries - they are around 100 plus freight on fleabay Link to comment https://www.fordxr6turbo.com/forum/topic/80918-what-did-you-do-to-your-car-today/page/146/#findComment-1319412 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 17y 18d Gender: Male Location: Adelaide Posted 02/11/12 05:49 AM Share Posted 02/11/12 05:49 AM j@ is a gun jetsnot is a huge ohmo 2 Link to comment https://www.fordxr6turbo.com/forum/topic/80918-what-did-you-do-to-your-car-today/page/146/#findComment-1319417 Share on other sites More sharing options...
Impellor Member 835 Member For: 14y 10m 29d Gender: Not Telling Posted 02/11/12 06:11 AM Share Posted 02/11/12 06:11 AM After all the catch can euphoria I got myself one. Calibre Supercheap item. Took out bottom bolt and used a screwdriver to push the top off (after taking all allenkey bolts out). Then proceeded to grind away internal inlet region so that I could get some piping around the inlet bolt. So as to make for a better unit air/oil separator, took about an hour. 2 stainless scourers fitted. I got a polished item (all they had). After a run I was surprised how hot it actually got. So thermodynamically speaking a black one would have been better. Im now think that I will run my rocker breather (front) into it via a barbed Y connector and vent all to atmo. As I was very surprised by the heat generated. Having that hot vapour feeding straight into the inlet manifold is not good for power. So I do think that this is a very worthwhile mod, with multiple benefits. Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/80918-what-did-you-do-to-your-car-today/page/146/#findComment-1319429 Share on other sites More sharing options...
Kroozin Menace Donating Members 1,990 Member For: 14y 1m 28d Gender: Male Location: Sydney Posted 02/11/12 07:15 AM Share Posted 02/11/12 07:15 AM (edited) Got any pics mate?Does much oil go into the can? Edited 02/11/12 07:17 AM by Kroozin Link to comment https://www.fordxr6turbo.com/forum/topic/80918-what-did-you-do-to-your-car-today/page/146/#findComment-1319453 Share on other sites More sharing options...
Impellor Member 835 Member For: 14y 10m 29d Gender: Not Telling Posted 02/11/12 07:32 AM Share Posted 02/11/12 07:32 AM On 02/11/2012 at 7:15 AM, Kroozin said: Got any pics mate?Does much oil go into the can?No sorry no pics. Only new so to early to say. But I will say this; due to the high temps I have little doubt that most of the oil content would probably still end up in the intake. Ideally a heat exchanger would benefit the system (located before catch can entry point, for best results). In the meantime I going to put a $3 fuel filter in the line (before catch can) and see if that helps by 1. slowing the flow, 2. providing greater surface area for cooling. But I honestly believe that if vented to atmo you would see BIG benefits.Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/80918-what-did-you-do-to-your-car-today/page/146/#findComment-1319462 Share on other sites More sharing options...
Kroozin Menace Donating Members 1,990 Member For: 14y 1m 28d Gender: Male Location: Sydney Posted 02/11/12 07:35 AM Share Posted 02/11/12 07:35 AM Ok so for the slow folk like me its just the 2 hoses from the rocker cover going into a catch can and one hose from the catch can going somewhere out of sight with a filter? No 1 way valves or anything needed now coz its not connected to the inlet manifold anymore, right? Link to comment https://www.fordxr6turbo.com/forum/topic/80918-what-did-you-do-to-your-car-today/page/146/#findComment-1319463 Share on other sites More sharing options...
Kosij Donating Members 2,045 Member For: 13y 10m 8d Gender: Male Posted 02/11/12 08:06 AM Share Posted 02/11/12 08:06 AM All done, just needs a intake cover. Booked in for touch up tune on Wednesday then straight to the drags at wsid.... Any guess what difference the plenum will make? Link to comment https://www.fordxr6turbo.com/forum/topic/80918-what-did-you-do-to-your-car-today/page/146/#findComment-1319477 Share on other sites More sharing options...
KeddyXR6T Donating Members 320 Member For: 16y 3m 12d Gender: Male Location: Melbourne Posted 02/11/12 08:11 AM Share Posted 02/11/12 08:11 AM Let us know what difference the plenum makes I'm going to try a snort 1000 plenum what type have you fitted there Link to comment https://www.fordxr6turbo.com/forum/topic/80918-what-did-you-do-to-your-car-today/page/146/#findComment-1319480 Share on other sites More sharing options...
Impellor Member 835 Member For: 14y 10m 29d Gender: Not Telling Posted 02/11/12 08:13 AM Share Posted 02/11/12 08:13 AM On 02/11/2012 at 7:35 AM, Kroozin said: Ok so for the slow folk like me its just the 2 hoses from the rocker cover going into a catch can and one hose from the catch can going somewhere out of sight with a filter? No 1 way valves or anything needed now coz its not connected to the inlet manifold anymore, right?Your all over it !!!! You will need a 10mm Y barbed fitting ($4.60 ebay). Join both PCV and rocker breather (using Y connector) to the catchcan inlet. Then run the piping from outlet down to a hidden location. But make sure you use a small breather filter on the end to be certain that it does'nt becomed blocked by little creatures, mud, dirt etc. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/80918-what-did-you-do-to-your-car-today/page/146/#findComment-1319481 Share on other sites More sharing options...
