Puffwagon Puff Gold Donating Members 16,284 Member For: 10y 2m 19d Gender: Male Location: South Australia Posted 30/11/23 06:28 AM Share Posted 30/11/23 06:28 AM It gets hot af in my neck of the woods. Even with a partially farked thermostat ie: only opened 5mm, my 100% stock car would only reach half way on the gauge, probably about 100C. Now that the thermostat is replaced it will be a bit better, we'll see after the next set of ball joints arrive. Turbo car turned up to kill, you would do one run through the gears and the gauge would go from 1/4 to over half. A couple of runs and it would be at 3/4. Link to comment https://www.fordxr6turbo.com/forum/topic/80918-what-did-you-do-to-your-car-today/page/1038/#findComment-1721157 Share on other sites More sharing options...
Slowxr6t Member 574 Member For: 6y 4m 13d Location: New zealand Posted 30/11/23 08:02 AM Share Posted 30/11/23 08:02 AM Damn 3/4 must be cooking, do those big 55mm pwr radiators make a big difference? Anyone tried them? Link to comment https://www.fordxr6turbo.com/forum/topic/80918-what-did-you-do-to-your-car-today/page/1038/#findComment-1721159 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,284 Member For: 10y 2m 19d Gender: Male Location: South Australia Posted 30/11/23 08:26 AM Share Posted 30/11/23 08:26 AM Nah 3/4 is fine, probably around 105C. The gauge pegs at about 110C and the car goes into limp mode at 120C or thereabouts. A bigger radiator wont keep it cooler, it'll just take longer to heat up. As for trying one, I haven't but it's on the list for the turbo car. Link to comment https://www.fordxr6turbo.com/forum/topic/80918-what-did-you-do-to-your-car-today/page/1038/#findComment-1721162 Share on other sites More sharing options...
Tom Tucker Donating Members 701 Member For: 5y 9m 18d Posted 30/11/23 10:21 AM Share Posted 30/11/23 10:21 AM Installation of Aeropro facia, modified to accept Haltech CAN pad: 2 Link to comment https://www.fordxr6turbo.com/forum/topic/80918-what-did-you-do-to-your-car-today/page/1038/#findComment-1721165 Share on other sites More sharing options...
El Andrew Gold Donating Members 2,036 Member For: 9y 11m 26d Gender: Male Location: Canberra ACT Posted 30/11/23 10:21 AM Share Posted 30/11/23 10:21 AM Good tip. Also makes it less socially unacceptable when the car pisses itself all over a car park.I find my fans almost never turn on unless it's 35 degrees and heavy traffic. Neither of those happen often, especially concurrently, in Canberra.Edit: really tempted on the Aepro fascia. Means you can throw in any old double DIN as the mood takes you, which to me.seema a better bet than the Kayhan Link to comment https://www.fordxr6turbo.com/forum/topic/80918-what-did-you-do-to-your-car-today/page/1038/#findComment-1721166 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,284 Member For: 10y 2m 19d Gender: Male Location: South Australia Posted 30/11/23 10:24 AM Share Posted 30/11/23 10:24 AM Your fans should be on with the aircon. Mine even come on with the heater if the climate control is set to auto. Dunno what the go is with that. Link to comment https://www.fordxr6turbo.com/forum/topic/80918-what-did-you-do-to-your-car-today/page/1038/#findComment-1721167 Share on other sites More sharing options...
Tom Tucker Donating Members 701 Member For: 5y 9m 18d Posted 30/11/23 10:30 AM Share Posted 30/11/23 10:30 AM On 30/11/2023 at 10:21 AM, El Andrew said: Good tip. Also makes it less socially unacceptable when the car pisses itself all over a car park. I find my fans almost never turn on unless it's 35 degrees and heavy traffic. Neither of those happen often, especially concurrently, in Canberra. Edit: really tempted on the Aepro fascia. Means you can throw in any old double DIN as the mood takes you, which to me.seema a better bet than the Kayhan Expand Yep, chucked in a high end Kenwood unit with Android auto, crystal clear reverse camera etc. Works perfectly with steering wheel controls. Link to comment https://www.fordxr6turbo.com/forum/topic/80918-what-did-you-do-to-your-car-today/page/1038/#findComment-1721168 Share on other sites More sharing options...
El Andrew Gold Donating Members 2,036 Member For: 9y 11m 26d Gender: Male Location: Canberra ACT Posted 30/11/23 10:44 AM Share Posted 30/11/23 10:44 AM I'll check that out. Compressor probably hasn't kicked in for about 9 months here so maybe I'm mistaken. Link to comment https://www.fordxr6turbo.com/forum/topic/80918-what-did-you-do-to-your-car-today/page/1038/#findComment-1721169 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,284 Member For: 10y 2m 19d Gender: Male Location: South Australia Posted 30/11/23 10:57 AM Share Posted 30/11/23 10:57 AM I swapped my thermostat yesterday, spilt some coolant on the aircon compressor, the belt did a burnout on it until the coolant dried up. Weird to see the compressor hardly moving with the car idling. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/80918-what-did-you-do-to-your-car-today/page/1038/#findComment-1721171 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,284 Member For: 10y 2m 19d Gender: Male Location: South Australia Posted 05/12/23 11:15 AM Share Posted 05/12/23 11:15 AM Got the na territory back together yesterday. Now that the wheel bearings are quiet I can hear the diff whining. Probably should see if it's got oil in it. I started doing some rust repair on my Landrover today. Nothing too hectic, I suppose I'll chuck some pics up tomorrow. Haha I get the tig fired up and the wind decides that it's time to sing the song of it's people Link to comment https://www.fordxr6turbo.com/forum/topic/80918-what-did-you-do-to-your-car-today/page/1038/#findComment-1721258 Share on other sites More sharing options...
