JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 7m 11d Gender: Male Location: Adelaide Posted 17/03/22 09:48 PM Share Posted 17/03/22 09:48 PM How about Mopar Purple…. 2 1 Link to comment Share on other sites More sharing options...
spook Donating Members 180 Member For: 16y 9m 7d Gender: Male Posted 18/03/22 12:55 AM Share Posted 18/03/22 12:55 AM 23 hours ago, El Andrew said: Did my first Subaru service. They are weird things but was probably the easiest oil change I've ever done. Fuel system additives and upper engine cleaner was a new world for me. Unfortunately too they use blue coolant so I didn't have any in stock. Realised after I'd pulled off 19 plastic rivets to get the shields off to access the radiator drain. So will finish that but tonight. Speaking of Subaru's.... Have an 07 Impreza as my daily since the XR6 is consigned to the odd weekend run. Just did an upper engine clean on it also. Like working on these things - have done all the usual maintenance tasks such as timing belt kit, water pump, plugs, cam cover gasket, all fluids etc. Was my sons car till he wanted a manual. So he now has a 09 RX and a box of bits ready to be installed. Looks like I have a busy weekend ahead.... 5 Link to comment Share on other sites More sharing options...
Puffwagon Trust me bro... Gold Donating Members 16,047 Member For: 9y 11m 13d Gender: Male Location: South Australia Posted 18/03/22 08:14 AM Share Posted 18/03/22 08:14 AM Busy indeed! I put my T55 torx bit to use today and got the oil changed in the gearbox of the landrover. The stuff that came out was farked!!! it was dirty and had a fair amount of metal through it. The box shifts better, not that it was too bad before. Turns out that topping stuff up reveals every leak that is there. The transfer case is leaking but that's an easy fix. I should have done it yesterday but couldn't be farked. The rear pinion seal is leaking, once again an easy fix but more work to do. There is an engine oil leak from somewhere and the front diff is covered in oil, probably from the engine but knowing my luck it'll be leaking too. All easy sh*t to fix but time consuming. Pics of gearbox oil... 1 Link to comment Share on other sites More sharing options...
Slowxr6t Member 563 Member For: 6y 1m 7d Location: New zealand Posted 19/03/22 08:29 AM Share Posted 19/03/22 08:29 AM @Puffwagonquestion for you puff, I have a 14psi spring in my ts 45mm wastegate, top port of gate is open. In 4th gear I get a bit of boost surge up in the rpms. If I plumb comp outlet tube to bottom port of gate as well as tee it to stock boost solenoid in port and then from out port of boost solenoid to top port of gate will this give better boost control? My other car a 300zx with single to4z has profec b boost controller and is plumbed like that and has perfect boost control. Link to comment Share on other sites More sharing options...
Puffwagon Trust me bro... Gold Donating Members 16,047 Member For: 9y 11m 13d Gender: Male Location: South Australia Posted 19/03/22 08:37 AM Share Posted 19/03/22 08:37 AM (edited) It might but you'd need to retune the pcm for the change in required wastegate duty cycle. The usual thing to do with boost creep is to use a bigger wastegate. Without actually logging the car and seeing the tune I can't give you a definite answer. Edit: It might not even be an issue with the wastegate. Edited 19/03/22 09:25 AM by Puffwagon Link to comment Share on other sites More sharing options...
Puffwagon Trust me bro... Gold Donating Members 16,047 Member For: 9y 11m 13d Gender: Male Location: South Australia Posted 01/05/22 05:39 AM Share Posted 01/05/22 05:39 AM Did the valve lash in the honda today. Ran the gaps down to as tight as they recommend then quarter of a thou more Farken thing is quieter and feels stronger all round. Just need a fully sick subwoofer and I'll be set 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,129 Member For: 16y 9m 1d Gender: Male Location: Melbourne Posted 01/05/22 05:48 AM Share Posted 01/05/22 05:48 AM how does valve lash repair mean you need a sub? not saying you don't need a sub, but I'm just curious haha Link to comment Share on other sites More sharing options...
Puffwagon Trust me bro... Gold Donating Members 16,047 Member For: 9y 11m 13d Gender: Male Location: South Australia Posted 01/05/22 05:58 AM Share Posted 01/05/22 05:58 AM Yeah nah it doesn't. I spose there's a couple more things to do to it, but having better sound quality/volume will make it heaps better. Pity I'm a fresh out the tube noob when it comes to car audio. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,129 Member For: 16y 9m 1d Gender: Male Location: Melbourne Posted 01/05/22 06:04 AM Share Posted 01/05/22 06:04 AM Go to a car audio joint reasonably close to you and get a quote for the best quality audio you can get for your budget (bank on $1000 at a minimum for a quality setup, probably more like $1500 for a good quality modern setup) based on what sort of music you like to listen to Link to comment Share on other sites More sharing options...
Puffwagon Trust me bro... Gold Donating Members 16,047 Member For: 9y 11m 13d Gender: Male Location: South Australia Posted 01/05/22 07:03 AM Share Posted 01/05/22 07:03 AM Yeah nah I don't pay people for stuff unless I absolutely have to. I haven't decided yet if it all gets tossed or I just add to it. It's got a clarion dxz586usb head unit and some clarion srq1630r 3 way speakers in the front and rear. The speakers still sound ok but are slightly rooted so yerp, thinking to upgrade soon. Link to comment Share on other sites More sharing options...
