Guest XR09
  • Guests
Keep an eye on the insides of your tyres.
You will soon find if they just dialed in the alighnment to Fords specs. Or gave it a propper one sitting as it is. The inners will be scrubbing out. You might find you have a darker strip up the inside fronts. Rears too maybe.
t will settle. IThat's why it will need one on a thousand k's. It will settle a bit. And that will be enough to move the numbers a little.
Not sure on the BF's. But I'm thinking you wouldn't need a camber kit @ that ride height. Unless your playing hard.
I like mine @ 1.7 neg camber. Think you can get 1.9 on the front without the need for a kit.
  • Thooperrrrrrr
  • Member For: 13y 9m 26d
Ah really? I only really drive suburban, bunch of streets and a little bit of highway (maybe 4-5kms a day highway)
Bought the camber kit straight away when they called me lol, spewwin!
  • Forged Member
  • Member For: 18y 2m 21d
I normally view the Toe in mm, but there isn't really anything wrong with that set-up. Perhaps I'd set the toe in a bit more to off set some of the inner edge wear. Particularly since you have the original rubber bushes in the front lower control arms.
As mentioned before though, considering you have the kit you might as well install it so there is more adjustment available if it is ever needed.
  • Forged Member
Having another look at the figures, they actually pulled some caster out of the passenger side for some reason - I would've left that as it was to off set the road camber
