Coolant Turned To Brownish Colour
sassXR6T
  • Member For: 14y 4m 7d
Check all the above and look into changing to a Tectalloy 90 or 100 ready mix.
You will required 2 X 5Ltr bottles of coolant Plus 2ltr demineralised water, if you want to do a full flush and fill. I did mine a week ago and now the temp gauge is steady at just a whisker above 1/4 mark.
Edited by 601Turbz
  • Member For: 12y 6m 10d
ok couldn't smell any exhaust gases while running so bit of relief.
whats the best way to dump all the coolant from radiator and block without to much trouble? is there a drain plug underneath or just pull bottom hose off?
  • Member For: 13y 9m 9d
You won't smell them mate. Unless the gasket is totally furked. You will need a little pump with testing fluid in a couple different chambers. You pump it over the open resiovouir at operating temperature and the liquid changes colour if exhaust gases are present.
99% of mechanics will have these and shouldn't charge anything to test :)
My bad should of explained better.
Ok well I put a Nulon radiator flush through dumped it then ran fresh water and dumped that finishing with a 50/50 mix of Nulon coolant.
Hopefully never see that brown sh*t again.. didn't smell to healthy either :stinker:
  • 4 weeks later...
  • Member For: 15y 5m 1d
good to know, mine has gone to an odd brownish colour which does look terrible. I remember when the car was new it was bright green and healthy looking.
