  • Thooperrrrrrr
  • Member For: 13y 11m 6d
Yup usually have about a 3rd of a bottle left after a flush here.
  • Member For: 14y 2m 3d
  On 06/07/2012 at 5:43 AM, Wenier said:
If you own a compressor get a vacuum bleeder and its an easy 1 person job, you dont even have to press the pedal.
Yeah we use a suction pump at work in same fashion for fluid change. Although a proper two person bleed always yields better results if done properly. The vacuum can sometimes draw air through the thread.
If the nipples aren't drawing don't stress. Fully undo them unblock the little hole with a pin or needle then smash compressed air down it. Put it back in and all good :)
  • 4 weeks later...
  • Member For: 13y 4m 30d
hey guys, can anyone tell me what sort of milage, the brake fluid should be changed at? I'm at 53,000 and im about to change pads over as there shot.
cheers
