adrian_celati Donating Members 82 Member For: 16y 2m 28d Gender: Male Posted 06/07/12 02:28 AM Share Posted 06/07/12 02:28 AM Hi folks,Has anyone here changed their own brake fluid and bled the brakes before on a car with ABS? I've done this before on a car without ABS with someone pumping the brake pedal while I bled the brakes. Just wanted to check if I can still do this on my XR6T.Thanks in advance. Link to comment Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 4m 16d Gender: Male Location: SE Melbourne Posted 06/07/12 02:40 AM Share Posted 06/07/12 02:40 AM Yes you can. Just don't let fluid go back the other way.Loosen bleed > depress pedal > tighten bleed > release pedal > repeat.Don't pump with the bleeder undone. 1 Link to comment Share on other sites More sharing options...
Ciaran Thooperrrrrrr Donating Members 2,768 Member For: 13y 9m 5d Gender: Male Location: NOR, Western Australia Posted 06/07/12 02:42 AM Share Posted 06/07/12 02:42 AM Just remember back passenger -> back driver -> front passenger -> front driver order and what Paulie said. Link to comment Share on other sites More sharing options...
adrian_celati Donating Members 82 Member For: 16y 2m 28d Gender: Male Posted 06/07/12 02:57 AM Author Share Posted 06/07/12 02:57 AM Thanks guys, yeah must start with furthest from the master cylinder and not release the brake pedal with the bleed screw undone. Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 6m 15d Gender: Male Location: Perth Posted 06/07/12 02:57 AM Share Posted 06/07/12 02:57 AM On 06/07/2012 at 2:40 AM, Paulie2256 said: Yes you can. Just don't let fluid go back the other way.Loosen bleed > depress pedal > tighten bleed > release pedal > repeat.Don't pump with the bleeder undone.this On 06/07/2012 at 2:42 AM, Ciaran said: Just remember back passenger -> back driver -> front passenger -> front driver order and what Paulie said.+this+drain the MC reservoir first with a large syringe, top up with fresh fluid then do as above, will speed up the process and save fluid. Link to comment Share on other sites More sharing options...
Guest XR09 Guests Posted 06/07/12 04:08 AM Share Posted 06/07/12 04:08 AM Use a decent brake fluid. Makes a huge diff. Penrite sin is good value. Motul gets good reviews. AndI think APS make their own, or have their name on one.If your wiping out the brake reservoir, use a clean rag and wet it with brake fluid before you stick it in there.If I am by myself I will let gravity bleed the brakes.Just keep an eye on the MC reservoir so it doesn't empty.Get a 6 pack and have a jam. Link to comment Share on other sites More sharing options...
Ciaran Thooperrrrrrr Donating Members 2,768 Member For: 13y 9m 5d Gender: Male Location: NOR, Western Australia Posted 06/07/12 05:14 AM Share Posted 06/07/12 05:14 AM +1 for Penrite Sin. Slightly more expensive but worth it Link to comment Share on other sites More sharing options...
1600dave Donating Members 872 Member For: 14y 2m 28d Posted 06/07/12 05:34 AM Share Posted 06/07/12 05:34 AM How many 500ml bottles to do a flush?Also if your not confident, don't mess with brakes! Whats a flush worth these days from a mechanic anyway? Last car I got done for $50. Link to comment Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 4m 16d Gender: Male Location: SE Melbourne Posted 06/07/12 05:42 AM Share Posted 06/07/12 05:42 AM 2 bottles is always more than enough for me. Link to comment Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 15y 2m 20d Gender: Male Location: Christchurch, New Zealand Posted 06/07/12 05:43 AM Share Posted 06/07/12 05:43 AM If you own a compressor get a vacuum bleeder and its an easy 1 person job, you dont even have to press the pedal. 1 Link to comment Share on other sites More sharing options...
