  • Member For: 16y 5m 1d
Hi folks,
Has anyone here changed their own brake fluid and bled the brakes before on a car with ABS? I've done this before on a car without ABS with someone pumping the brake pedal while I bled the brakes. Just wanted to check if I can still do this on my XR6T.
Thanks in advance.
https://www.fordxr6turbo.com/forum/topic/80858-changing-brake-fluid/
  • Member For: 16y 6m 20d
Yes you can. Just don't let fluid go back the other way.
Loosen bleed > depress pedal > tighten bleed > release pedal > repeat.
Don't pump with the bleeder undone.
  • Thooperrrrrrr
  • Member For: 13y 11m 9d
Just remember back passenger -> back driver -> front passenger -> front driver order and what Paulie said.
  • Moar Powar Babeh
  • Member For: 19y 8m 19d
this
+this
+drain the MC reservoir first with a large syringe, top up with fresh fluid then do as above, will speed up the process and save fluid.
Guest XR09
  • Guests
Use a decent brake fluid. Makes a huge diff. Penrite sin is good value. Motul gets good reviews. AndI think APS make their own, or have their name on one.
If your wiping out the brake reservoir, use a clean rag and wet it with brake fluid before you stick it in there.
If I am by myself I will let gravity bleed the brakes.
Just keep an eye on the MC reservoir so it doesn't empty.
Get a 6 pack and have a jam.
  • Member For: 15y 4m 24d
If you own a compressor get a vacuum bleeder and its an easy 1 person job, you dont even have to press the pedal.
