Plenum & Race Box How Much More Hp?
  • Member For: 12y 10m 15d
Hi ive got a 07 bf ute that makes 309rwkw, it has a xforce 4 inch dump, big cat twin 2.5 system, nizpro cooler, id 1000 injectors, walbro pump and a standard opened up air box, if I get an intake plenum and a race air box how much more power will it make? Would I be better off getting a surge tank and e85 tune instead?
  • flame magnet
  • Member For: 16y 9m 10d
dont need a surge so much for a ute. ultimately just a precaution. valve springs will need to be looked at next...
  • Member For: 14y 7m 27d
Don't worry about a plenum atm. I would've thought you'd be making more than 309 atm to be honest. What boost is it running ?
Next I would have thought air box, so your piping is shorter, then perhaps a surge tank. E85 depends what state you live in. In VIC it's a pain in the ass to get unless your buying it in drums and then pretty costly.
Also valve springs may need replacing in the future but not atm I wouldn't have thought. Mine were starting to show signs of float with 18psi and over 370rwkw so I think you'll be right but each car is different.
Also look into a turbo port and stronger actuator.
Edited by webby324
  • Donkey Dick
  • Member For: 14y 11m 8d
You need larger injectors, twin pumps & fuel line that is compatible with Ethanol to run E85, not just a surge tank. Cost adds up if you do it properly...
Seeing as you already have ID1000's I'd be looking at twin 044 pumps mounted in the tray with a generic 3L surge tank, -6 teflon braided dual lines to a PW twin feed rail, aeromotive reg with -6 single teflon braided return line & a PW airbox tuned on E85.
  • Member For: 15y 9m 4d
Theres plenty of united servos that sell it in VIC
All the parts listed above are NOT required for your car to make decent power, you would only NEED a surge tank & 044
  • Like 2
  • Member For: 13y 10m 21d
I think slash meant to use those parts If intending to run on E85.
If it where my car I'd make a surge with 044, add a cold air intake, change the wastegate actuator and valve springs then retune
