matsfgxr6turbo Member 388 Member For: 15y 3m 11d Posted 22/06/13 02:53 PM Share Posted 22/06/13 02:53 PM as if it would need a tune people on this forum way are way to obessed with getting a tune for f*ck all if your not replacing the cat on any of these cars it doesn't require a tune end of story.A tiny restrictor ring removal isn't going to make it a high flow cat grind that baby out with no regrets 2 Link to comment https://www.fordxr6turbo.com/forum/topic/80710-fg-restrictor-ring/page/5/#findComment-1400545 Share on other sites More sharing options...
dan4.0t Member 14 Member For: 12y 5m Posted 30/06/13 01:16 AM Share Posted 30/06/13 01:16 AM well, my mate and I spent the Sunday morning grinding out that ring on my car, wasn't as bad as we thought but not entirely sure it made a big difference or not.feels like it spools a little quicker, but yer I don't know for sure, but I do know that it should be pumping the waste gas out easier now without any unnecessary restrictions, least till I get a proper exhaust Link to comment https://www.fordxr6turbo.com/forum/topic/80710-fg-restrictor-ring/page/5/#findComment-1402603 Share on other sites More sharing options...
Dimitry New Member 10 Member For: 17y 3m 22d Posted 13/07/13 08:18 AM Share Posted 13/07/13 08:18 AM Hi, Does anyone know a shop in Sydney that has done this mod before? I want to keep my car stock but would not mind taking this constrictor out. Link to comment https://www.fordxr6turbo.com/forum/topic/80710-fg-restrictor-ring/page/5/#findComment-1406407 Share on other sites More sharing options...
nullanulla Donating Members 9 Member For: 12y 10m 10d Gender: Male Posted 16/05/14 05:00 AM Share Posted 16/05/14 05:00 AM Day off work so thought I'd have a crack at taking out this restrictor ring. Going back to old go-kart days we used to have a restrictor ring put in to slow them down for the different classes and the difference it made from having it to out was like going from N/A to Turbo. This in mind by removing a ring that is in the exhaust could only be good for the engine.So this morning I jacked the car up and eventually got the exhaust bolts undone with some care not the brake them as they were pretty damn tight. Bit of WD40 helped enough to crack them and then was smooth sailing.Now to the grinding. After spending a hour looking for the die grinder I find out the brother has taken it and p*ssed off for a few days. So here I am with car up the exhaust apart and no Farking grinder to get the thing out. I spent another half hour looking for something else to use and finally came across a couple of old Cold Chisels and a lump hammer. With some careful precision and a few strong belts the Restrictor ring started to shift and before you know it she was out. There was only three small tack welds so the chisel and lump easily sorted them out.Bolted it all back together and went for a drive and definitely noticed there was a little more bottom end. My car is stock and a Mk2 FG manual. There gear changes between first and second the car seemed to pick up quicker and not drop off as much between changes at low RPM. Definitely worth having a crack at if you have an hour or so to kill. Link to comment https://www.fordxr6turbo.com/forum/topic/80710-fg-restrictor-ring/page/5/#findComment-1471898 Share on other sites More sharing options...
shaness8 Member 89 Member For: 15y 9m 13d Gender: Male Posted 16/05/14 01:58 PM Share Posted 16/05/14 01:58 PM So potentially the early models FG turbo's would make more power at the wheels due to not having the restrictor.I'm doing mine tomorrow. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/80710-fg-restrictor-ring/page/5/#findComment-1472003 Share on other sites More sharing options...
Rollin Member 33 Member For: 16y 2m 8d Posted 16/05/14 02:06 PM Share Posted 16/05/14 02:06 PM Between the Territory butt plug and the FG tighter ring hole it really does appear ford was trying hard to keep the Turbos' power production back to a marketing friendly number... Link to comment https://www.fordxr6turbo.com/forum/topic/80710-fg-restrictor-ring/page/5/#findComment-1472008 Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 14y 6m 25d Gender: Male Posted 16/05/14 08:26 PM Share Posted 16/05/14 08:26 PM For some reason Mk2 turbos seem to make good power with restrictor ring.. I've made 245 stock and seen a few others around that mark also..It's not to kerb power I think, it's to hear up cat quicker for better emissions. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/80710-fg-restrictor-ring/page/5/#findComment-1472014 Share on other sites More sharing options...
shaness8 Member 89 Member For: 15y 9m 13d Gender: Male Posted 17/05/14 12:35 PM Share Posted 17/05/14 12:35 PM Did mine today, took some measurements exhaust is 2 3/4 inch on the inside the ring is only 2 1/4 inch.Car has definitely picked up some power. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/80710-fg-restrictor-ring/page/5/#findComment-1472129 Share on other sites More sharing options...
Rab WOT? Moderating Team 10,981 Member For: 12y 2m 22d Gender: Male Location: Frankston, 3199 Posted 18/05/14 03:09 AM Share Posted 18/05/14 03:09 AM Am guessing the euro 5 cat on the newer models had a bit more flow than the previous ones.Restrictor was to even it up with the previous ones so they didn't need to adjust anything when they went to the new cat. Link to comment https://www.fordxr6turbo.com/forum/topic/80710-fg-restrictor-ring/page/5/#findComment-1472199 Share on other sites More sharing options...
