Steering Wheel Shakes When Driving
LazyBrennan
  • Member For: 13y 11m 18d
Over tightening wheel nuts can cause irreversible brake shudder.
If it were my car id check wheel balance, tyre pressures, rotor runout and wheel alignment.
A checklist for all of those should pinpoint what is going wrong.
I'd run a higher pressure in the rear if I were you.
Best of luck mate.
Cheers mate.
Do you know what the proper NM the wheel nuts should be?
I did retighten the wheel nuts recently. After getting the car back from Peel tyres in Mandurah all the wheel nuts were loose as. I could move some with my fingers =/
Edited by LazyBrennan
  • Turboless
  • Member For: 14y 12d
They're rings you put inside the bore of the wheel to make sure the wheel is centred perfectly.
This page explains it best and has a pic :)
http://www.justforwheels.com/hub-centric-rings.jsp
  • Member For: 13y 11m 6d
Cheers mate.
Ford specifies: 135 NM :)
