More Power !
IMLOCO
  • Member For: 14y 1m 5d
Sounds like you might be better off going for about 270kw first with just a tune from where you are (plus cat mod) and save for the rest of it .
You will need to spend some money to get 300kw on the clutch, flapper mod and actuator and probably springs anyway so why not target what the existing mods will support for now?
I agree with Henz on the surge tank too. No point hacking the tank pump.
  • Member For: 12y 11m 7d
Yeah I'd be happy with that for the time being until I get enough funds saved up for the rest ... Should I do injectors as well as the cat and a tune ? Do u reccomend any good cats or just a hi flow ? What's a good one woth these days? my last car I bought with all the gear on it and I want to do all the mods to the way I like it this time ..
  • Menace
  • Member For: 13y 10m 2d
its up to you... I think the stock injectors max out around 255-275rwkw but in saying that so will your valve springs and clutch maybe even your actuator depends really.
The injectors could wait IMO if you cant afford the rest of the bits and pieces to use the bigger injectors as intended.
  • Member For: 17y 7m 29d
You'll be lucky to screw 250rwkw with those valvesprings then.
I had issues with valvesprings only having done 10,000kms on the clock.
Edited by xr6t_ute
