Ciaran Thooperrrrrrr Donating Members 2,768 Member For: 13y 10m 1d Gender: Male Location: NOR, Western Australia Posted 14/06/12 01:28 AM Share Posted 14/06/12 01:28 AM Sorry if hi-jacking, but on the note of combination switch buggered, could that be the same for the issue I'm having with my wipers and the water not spraying when I pull back the lever? The wipers move, but no water sprays out when trying to wash my windscreen. Link to comment https://www.fordxr6turbo.com/forum/topic/80576-lights-not-turning-on-could-be-combination-switch/page/2/#findComment-1253765 Share on other sites More sharing options...
Shyfrd Turboless Donating Members 5,992 Member For: 14y 2m 6d Gender: Male Location: Geelong, Victoria Posted 14/06/12 01:52 AM Share Posted 14/06/12 01:52 AM Worth a looksie ciaran. Couple of screws to undo on the underside and then pull the top off and then should be able to see the wiring. Link to comment https://www.fordxr6turbo.com/forum/topic/80576-lights-not-turning-on-could-be-combination-switch/page/2/#findComment-1253778 Share on other sites More sharing options...
Ciaran Thooperrrrrrr Donating Members 2,768 Member For: 13y 10m 1d Gender: Male Location: NOR, Western Australia Posted 14/06/12 02:07 AM Share Posted 14/06/12 02:07 AM What will it look like if buggered? Just loose wires? Link to comment https://www.fordxr6turbo.com/forum/topic/80576-lights-not-turning-on-could-be-combination-switch/page/2/#findComment-1253784 Share on other sites More sharing options...
Weaponxr Donating Members 624 Member For: 14y 4m 22d Gender: Male Location: Melbourne Posted 14/06/12 02:07 AM Author Share Posted 14/06/12 02:07 AM Ok guys, after reading and googling the problem I have a better understanding of what the problems are with the combination switch.I found some sites with pictures where the wires seem to fray and break apart. When I come back to Australia I will pull the assembly out and have a look at the wires and I will attempt to repair them. Im not bad with the soldering iron and heat shrink lol.At least im feeling a little more relaxed about the issue as I thought I would have immediatley been up for a $395 peice of plastic Link to comment https://www.fordxr6turbo.com/forum/topic/80576-lights-not-turning-on-could-be-combination-switch/page/2/#findComment-1253785 Share on other sites More sharing options...
Ciaran Thooperrrrrrr Donating Members 2,768 Member For: 13y 10m 1d Gender: Male Location: NOR, Western Australia Posted 14/06/12 03:02 AM Share Posted 14/06/12 03:02 AM (edited) Just checked my combination switch. 2 wires on the wiper side, both seem pretty intact and in good condition.Probably the water pump assiciated to the wipers.Car booked in with City Motors to be fixed on Tuesday, won't cost me anything Edited 14/06/12 03:14 AM by Ciaran Link to comment https://www.fordxr6turbo.com/forum/topic/80576-lights-not-turning-on-could-be-combination-switch/page/2/#findComment-1253833 Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 15y 3m 15d Gender: Male Location: Christchurch, New Zealand Posted 14/06/12 06:51 AM Share Posted 14/06/12 06:51 AM (edited) The wiring has been a bit short on some peoples cars so what happens is where the wire exits the stalk into the steering column housing it is resting against the corner of the housing. Overtime and use of the stalks it then cuts the wire at that corner it has to take to follow the column to behind the dash. So it will just look like a cut wire or 2.Check out pic at end of this thread. http://www.fordxr6turbo.com/forum/topic/65575-blinker-switching-off-dashboard-background-lights/page__pid__1020486Almost need that topic pinned in electrical as this same issue has been brought up multiple times recently. Edited 14/06/12 06:55 AM by Wenier Link to comment https://www.fordxr6turbo.com/forum/topic/80576-lights-not-turning-on-could-be-combination-switch/page/2/#findComment-1253942 Share on other sites More sharing options...
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Donating Members 9,946 Member For: 17y 1m 14d Gender: Male Location: Vic Posted 14/06/12 08:39 AM Share Posted 14/06/12 08:39 AM On 14/06/2012 at 3:02 AM, Ciaran said: Just checked my combination switch. 2 wires on the wiper side, both seem pretty intact and in good condition.Probably the water pump assiciated to the wipers.Car booked in with City Motors to be fixed on Tuesday, won't cost me anythingI just had to replace washer motor. Mines bf2 FFS. Link to comment https://www.fordxr6turbo.com/forum/topic/80576-lights-not-turning-on-could-be-combination-switch/page/2/#findComment-1254020 Share on other sites More sharing options...
Ciaran Thooperrrrrrr Donating Members 2,768 Member For: 13y 10m 1d Gender: Male Location: NOR, Western Australia Posted 14/06/12 09:57 AM Share Posted 14/06/12 09:57 AM Yup mine bf2 as well, so it's a common thing you reckon?Did yours do the exact same thing mine did? Pull the lever and absolutely nothing happen? (no sound or anything from the motor but the wipers still work) Link to comment https://www.fordxr6turbo.com/forum/topic/80576-lights-not-turning-on-could-be-combination-switch/page/2/#findComment-1254073 Share on other sites More sharing options...
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Donating Members 9,946 Member For: 17y 1m 14d Gender: Male Location: Vic Posted 14/06/12 10:27 AM Share Posted 14/06/12 10:27 AM Yep. Link to comment https://www.fordxr6turbo.com/forum/topic/80576-lights-not-turning-on-could-be-combination-switch/page/2/#findComment-1254107 Share on other sites More sharing options...
Ciaran Thooperrrrrrr Donating Members 2,768 Member For: 13y 10m 1d Gender: Male Location: NOR, Western Australia Posted 14/06/12 10:55 AM Share Posted 14/06/12 10:55 AM Sweet problem solvered. Link to comment https://www.fordxr6turbo.com/forum/topic/80576-lights-not-turning-on-could-be-combination-switch/page/2/#findComment-1254131 Share on other sites More sharing options...
