Lost My Rear Turbo Wheel
fgxod
  • Member For: 13y 8m 13d
Bolts right up but!! You need to ask stee about the actuator bracket as it wount fit with a stock one. Also you don't have to run the bigger front housing you can keep your old front housing if you don't want to go 4" intake
  • Member For: 13y 6m 18d
so this turbo is straight bolt in?
Yes the intake was the only thing I really had to change. It was a sintch to bolt on. I used his rear housing and ported it for him then slid in the GTX centre. I aligned it and it all bolted up just like a standard turbo. I had more trouble bolting up the GTX to my B series than this FG. I had the turbo assembled and on in less than 3 hours. Waiting for him to get a surge tank and gut the cat then ill have a play around with it..
I was really worried at first I was only going to run the early model turbo 3540 core but then I said what if I want to go more then 400kw in the future. So stee said get the gtx35 fits right in and it's good for 430. Plus if your going to want more then that your going full house bacause motor needs opening. I guess if you go to that extent it's not a big deal to change dump, extractors and add a external waste gate
  • Member For: 14y 5m 28d
Once you get a surge tank, bigger injectors for a e-85 tune (unless you havern't changed injectors).
Nice I guess it's auto because you have g6? That would be a weapon what's the power and list of mods you got bro if you don't mind me asking
Getting surge tank tommorow bro and injectors are in got the 60lb. I'll run 100 off the pump
