geekatrons Member 60 Member For: 12y 10m 18d Posted 12/06/12 12:30 PM Author Share Posted 12/06/12 12:30 PM Hello All2003 BA XR6T- drives fine until I put foot flat to the floor. The Car will hit the 3500-4000 RPM then basically die- like it has cut fuel- then when I ease off accelerator and put foot back on it will drive again as normal. If I ease into the acceleration it pulls ok but if I put my foot down too much it almost floods itself or feels like it is starving of fuel or similar. I am unsure of what this could be- and am desperate of finding the solution I have done the following-I Have researched coil issue- however from what I have read this doesn't sound like the issue?Took car to one mechanic who wasn't sure but said it seems like it is a wastegate issue- he said that it appears that the wastegate could be ceased open? - he cleared an overboost error from the ECU also when checking it.Please help if you have had something like this or have any ideas of where I can start It is annoying me sooo much right now!! Link to comment Share on other sites More sharing options...
BigAl's04 Special needs member. Bronze Donating Members 690 Member For: 14y 6m 6d Gender: Male Location: gold coast Posted 12/06/12 12:38 PM Share Posted 12/06/12 12:38 PM Fuel filter? If your wastegate was stuck open it would struggle to make boost let alone overboost. I would start with fuel filter, air filter. Link to comment Share on other sites More sharing options...
Boogtonic Member 76 Member For: 13y 5m 15d Gender: Male Location: Brisbane Posted 12/06/12 01:54 PM Share Posted 12/06/12 01:54 PM Traction control? Turn it off and try again. Link to comment Share on other sites More sharing options...
bradles024 Donating Members 1,145 Member For: 15y 3m 26d Gender: Male Posted 12/06/12 03:39 PM Share Posted 12/06/12 03:39 PM My waste gate was stuck closed, car went hard as until about 3000rpm where it would just stop all of a sudden. Put it in the dyno and it was getting up to 20psi! Turned out to be turbo side engine mount was f*cked. Link to comment Share on other sites More sharing options...
_Velocity_ Bronze Donating Members 2,768 Member For: 13y 10m 15d Gender: Male Location: Victoria Posted 12/06/12 11:34 PM Share Posted 12/06/12 11:34 PM Sounds like the same problem that I had when I first got my T. For me it was the diaphragm in the turbo actuator that had split causing it to overboost.Took about 4-5 visits to the Ford dealership before they were able to identify the problem. Their mechanic told me the car would hit limp mode because the extra boost was causing it to run lean. Not sure if the computer in the Falcon can do this but this is what he told me. Link to comment Share on other sites More sharing options...
geekatrons Member 60 Member For: 12y 10m 18d Posted 13/06/12 10:08 AM Author Share Posted 13/06/12 10:08 AM Thanks for the input, I have tried the traction control on and off, no difference. The car was only serviced recently according to logbook. I doubt it would be a fuel filter or air filter but hey anything is possible and who knows how good the service was. I think the " diaphragm in the turbo actuator that had split causing it to overboost." is probably the most likely- I will get this looked at and see where to go from there.Velocity- What cost are we talking here and how hard is it to replace?Appreciate your help. Link to comment Share on other sites More sharing options...
_Velocity_ Bronze Donating Members 2,768 Member For: 13y 10m 15d Gender: Male Location: Victoria Posted 13/06/12 11:57 AM Share Posted 13/06/12 11:57 AM Mine was under warranty as I had bought the car from the dealership (second hand). They said that you have to remove the turbo to get to it but I think your best bet would be to take it somewhere that specialises in these cars. Might cost you a bit more short term but at least you will have peace of mind. What state are you in? 1 Link to comment Share on other sites More sharing options...
geekatrons Member 60 Member For: 12y 10m 18d Posted 13/06/12 12:25 PM Author Share Posted 13/06/12 12:25 PM I am in NSW- Sydney. I am yet to really find a mechanic that knows a lot about the XR6T without charging me the earth. I have a good general mechanic however pretty limited with finer detail and fault finding. May have a talk with my long term mechanic and then see how it all ends up. Link to comment Share on other sites More sharing options...
_Velocity_ Bronze Donating Members 2,768 Member For: 13y 10m 15d Gender: Male Location: Victoria Posted 13/06/12 01:20 PM Share Posted 13/06/12 01:20 PM There are a few forum sponsors in Sydney you could give a call. It might work out to be something that they can diagnose for you and your local mechanic can fix.Let us know how you go either way as it's always good to post a follow up in case someone has the same problem and reads your thread. Link to comment Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 14y 4m 18d Gender: Male Posted 13/06/12 07:31 PM Share Posted 13/06/12 07:31 PM Geez being in Sydney you have a abundance of XRT tuners to pick from, C&V performance Auto techBTATune house Hear very good things about BTA, give them a ring. Link to comment Share on other sites More sharing options...
