geekatrons Member 60 Member For: 13y 2m 14d Posted 12/05/12 09:45 PM Share Posted 12/05/12 09:45 PM Hello AllI need help. Just got a 2003 xr6t with 98k on clock. Driving around 40km distance was fine, ht boost a few times nothing crazy. About 2km from home gave it a good stab and then when turning into driveway the car shuddered badly (Through engine bay, not braking) and then stalled. (Please note this is an automatic). I then tried restarting and it studdered and turned over a few times before starting. I then drove car about 3km was fine then stabbed it again and the thing shuddered and stalled again. This time wouldn't start- I tried a few times just wouldn't start, then left sitting for 5 mins and it started again. I have noticed now in normal mode the car does't change up and hits rev limiter in third, when driving no issues only when giving it heaps? Any ideas would be much appreciated. I am thinking either fuel pump or computer issue. Is there anything else that it could be. normal driving fine- boosting car hard and it doesn't like it. Link to comment https://www.fordxr6turbo.com/forum/topic/80546-boost-issue-and-braking-steering-shudder/ Share on other sites More sharing options...
riptide Member 733 Member For: 14y 5m 18d Gender: Male Location: Auckland, New Zealand Posted 13/05/12 12:30 AM Share Posted 13/05/12 12:30 AM (edited) Valve springs?What boost are you running? Edited 13/05/12 12:31 AM by riptide Link to comment https://www.fordxr6turbo.com/forum/topic/80546-boost-issue-and-braking-steering-shudder/#findComment-1236325 Share on other sites More sharing options...
geekatrons Member 60 Member For: 13y 2m 14d Posted 13/05/12 01:26 AM Author Share Posted 13/05/12 01:26 AM I am not sure what boost it is running. I had a look around and have noticed that it has a chip torque exede computer controller also. Possibly something to do with that? The previous owner said that he had changed valve springs? If not what sort of cost am I looking at? I have a mate who works at envy dyno tuners so I will try and get the car on the dyno this week. I just don't really want to spend too much money atm.Any advise is appreciated Link to comment https://www.fordxr6turbo.com/forum/topic/80546-boost-issue-and-braking-steering-shudder/#findComment-1236343 Share on other sites More sharing options...
riptide Member 733 Member For: 14y 5m 18d Gender: Male Location: Auckland, New Zealand Posted 13/05/12 05:54 AM Share Posted 13/05/12 05:54 AM (edited) I had a quick look on their website and they seem a bit.....limited. Maybe it's just that I don't understand them properly but they don't seem very common.You may find it hard to get someone to tune it with that. Personally I would go with one of the mainstream tuning systems in-case that's the problem and it's difficult to diagnose.Alternatively there may be someone on here with knowledge of those that can help.Have you tried removing it assuming the injectors are standard, to see if it's the problem?I was just reading they are hard wired and you can purchase a bypass plug for $66 to disable it. Edited 13/05/12 05:59 AM by riptide Link to comment https://www.fordxr6turbo.com/forum/topic/80546-boost-issue-and-braking-steering-shudder/#findComment-1236447 Share on other sites More sharing options...
geekatrons Member 60 Member For: 13y 2m 14d Posted 13/05/12 10:13 AM Author Share Posted 13/05/12 10:13 AM Thanks for your reply. I haven't tried bypassing it yet. I will wait and find out if the Envy tunehouse can do anything. I am not really fussed with pushing the car- If it was to standard and had no issues wouldn't be too upset. I will keep you posted. Just came back from another drive and if I put foot flat it is still really laggy- if I gradually accelerate no issues seems to keep pulling and boosting. Link to comment https://www.fordxr6turbo.com/forum/topic/80546-boost-issue-and-braking-steering-shudder/#findComment-1236627 Share on other sites More sharing options...
Periklis Member 67 Member For: 14y 10m 26d Posted 16/05/12 12:35 PM Share Posted 16/05/12 12:35 PM I have same problem but mines a completely stock 02 5 speed xr6t Link to comment https://www.fordxr6turbo.com/forum/topic/80546-boost-issue-and-braking-steering-shudder/#findComment-1238382 Share on other sites More sharing options...
geekatrons Member 60 Member For: 13y 2m 14d Posted 17/05/12 11:26 AM Author Share Posted 17/05/12 11:26 AM I am taking mine to mechanic tomorrow. From further info I have I believe that it could be a valve issue- as per a previous post also. WIll find out what the go is soon. I have a 2011 mondeo I usually drive for work so don't drive the xr6t- however cannot deal with a car not running properly.First focus is the brake problem- getting slotted rotors and bendix brakes to get rid of the brake shudder problem. Getting back to car issue I have a gut feel that there may be a leaking hose somewhere under pressure?Will let u know Link to comment https://www.fordxr6turbo.com/forum/topic/80546-boost-issue-and-braking-steering-shudder/#findComment-1238909 Share on other sites More sharing options...
geekatrons Member 60 Member For: 13y 2m 14d Posted 18/05/12 10:55 AM Author Share Posted 18/05/12 10:55 AM Found half the problem. The air intake hose into the air box was loose which has resulted in the car going better than before. Still evidence of an ongoing issue- I think dyno time- Damned it! Link to comment https://www.fordxr6turbo.com/forum/topic/80546-boost-issue-and-braking-steering-shudder/#findComment-1239425 Share on other sites More sharing options...
THCOOK Member 58 Member For: 15y 11m 28d Gender: Male Location: sydney Posted 19/05/12 04:08 AM Share Posted 19/05/12 04:08 AM I t happenes with me too I think its something with the limiter. it only happens under big boost when it hits the limiter. Link to comment https://www.fordxr6turbo.com/forum/topic/80546-boost-issue-and-braking-steering-shudder/#findComment-1239686 Share on other sites More sharing options...
bionic_oosty Donating Members 241 Member For: 13y 5m 22d Gender: Male Location: Sydney/Wollongong Posted 19/05/12 05:50 AM Share Posted 19/05/12 05:50 AM if one clamp and hose were loose, I would be checking them all (im guessing u have already though). My throttle body hose was loose one time and it had issues on boost and starting. Gotta love these cars! Its endless lol Link to comment https://www.fordxr6turbo.com/forum/topic/80546-boost-issue-and-braking-steering-shudder/#findComment-1239736 Share on other sites More sharing options...
