No Boost - 2 Psi Max Maybe? Help
Brooksy-BFXR6T
  • 2 months later...
  • Member For: 12y 8m 8d
My car ever sinec changing the wastegate actuator has lost allot of power,mostly down low but on idle in gear (its a auto) has started making ticking noises from around the dump/cat area.cant pin point it but did undo a bolt on the dump pipe/turbo housing accidently then did it back up.Would I get a simple leak from that?
no I didnt I just lined it up and that was it.Starting to think yeah maybe the flapper isnt opening up far enough.Would that be the case?
  • Member For: 13y 5m 11d
Bionicxr6t05 is on the money. Screw the actuator arm in until it is half a hole short of slipping over the flapper arm then pull on the actuator (or use compressed air if available) to get it onto the arm.
I'd also put my money on this causing the 'ticking' noise that you're describing. The flap is probably rattling around due to no pre load holding it shut.
Edited by The Converted
ok cool thanx heaps yeah il give that a go today cos yeah I have boost but not much down low its more around the 60km/h onwards before it starts showing its true colours
