  • You've changed man....
  • Member For: 14y 5m 21d
  • Member For: 18y 8m 20d
Tbh the escort is a better looking car then the cortina,, just sh*tload more work making the motor fit
  • ʎǝʞuoɯ ɹoıuǝs
  • Member For: 16y 6m 1d
The weight starts to add up.
My ke20 went from 760kg to 850kg with just a 1600 turbo/box/diff/brakes/cooler. Had no rear seats even.
Thinking a barra/box/cage would be pretty hefty
  • Member For: 16y 15d
What sort of racing had you planned to do? If it's anything to do with circuit racing and the car's not road registered, Don't bother with a 4L turbo. CAMS (Confederation of Australian Motor Sport) The governing body controlling motor sport in Australia will not allow a race car to be log booked If it calculated engine capacity exceeds 6000cc. Unfortunately a turbo multiplies the engines capacity by 1.7 which make the calculated capacity 6800cc. How ever if you supercharge it, The capacity is only multiplied by 1.5 making it 6000cc.
  • Member For: 19y 21d
I think the op needs to work out what he wants the car for. ie street car, race car or burnout car etc
if street car he needs to talk to an engineer before spending any money and find out what is passable, but be warned, builds like this can take years to do and laws may change from start to finish.
if race car, what sort of races and what class, he will need to talk to the relevant controling body and then build it to the class rules, which may limit engine size, setback, suspension mods etc.
If burnout car, just build it safely and do not expect to use it anywhere else but a burnout comp/demo
good luck with the build if serious
  • 2 weeks later...
  • Member For: 16y 7m 18d
  On 03/06/2012 at 9:46 PM, STAINOnegger said:
Somethin to keep the back wheels from lifting off the ground.
Maybe a TE cortina a better option as engine bay is big enough for a 250 crossflow, might have more chance getting one of these in there.
*edit
Check this out
http://www.fullboost...321&postcount=5
I have sooooo wanted to do a TC with a barra....
