  • Cruise Control
  • Member For: 18y 3m 30d
Obviously you intend to race this thing right?.....
have you considered what class its going to fit into?...
  • Member For: 15y 10m 25d
My mate has a Escort with a 1jz, It had 320hp atw and weighed 1060kg. He's now halfway through fitting a GTX3071r to it.
Here's a video of it at Morgan Park, Just after he finished building it.
Here him at Mt Cotton Hillclimb, The smoke's from the rear turbos' damaged oil seal.
Edited by ScatterBrain
  • Member For: 17y 7m 29d
Any reason your set on an escort?
As mentioned before a Capri or Cortina would be more suitable. Would need plenty of money for all that fab work, front/rear end etc. And will u rego it?
  • flame magnet
  • Member For: 16y 11m 11d
that scort with the barra motor going in would be sucking biiiiiiig dollars to complete....
  • Member For: 17y 5m 22d
  On 03/06/2012 at 8:45 PM, Bomber said:
I think in most states also if you modify the f/wall you won't be able to register.
I've modified my fire wall and the car is getting fully engineered, A Cortina will also need a firewall job to make it fit with a nice amount of room, the added benefit over a Escort is a Capri and Cortina can run an engine up to 5ltr in Capacity, so a 4ltr is well within the limit's, but this in Vic of course, my chassis guy also has found a loop hole to have the car fully engineered with the 6 point chromoly cage which will be getting done aswell...
Be prepared to be forking out lot's of $$, if you dont have lot's of $$ to back you dont even think about starting such a conversion...
This is takin from fullboost forum's record list, it's a Cortina with a Barra im not sure this pic will work...
Here's the time it ran...
Jim Grillis
Ford Cortina DOHC 4.0L turbo
8.580 @ 163.50mph
28x9in slicks, E100 fuel
Couple of older video's of it, car run's a GT42 im sure and a C4....
Edited by JETFPV
  • Waiting for the 1st N/A 12!
  • Member For: 17y 2m 16d
There's also a Eskie Panel Van with a Barra T in it!
I'll try and find the links, it was for sale when I saw it!
Stand by.
